VFSV6FORME
- Mar 9, 2016
- 2,603
- 1,273
- 113
- Age
- 74
- Location
- Brisbane
- WN Caprice V 6.0L, VE Anniversity V6 Series 1
Same hereMy 2010 S1 VE Calais has a strange issue. Sometimes (80% of the time) when I turn the car on, the air doesn't come out of the chest high vents. comes out of the feet and windscreen no problems. If i hold the demister button for the 10 seconds, resets no problems. Also, if I turn to ignition setting, 90% time it works, but as soon as I start the car, it dies. Any idea what this would be? Is there a control module that is forgetting the settings when its turned off?
Turn the Ignition on then select or leave the fan selector on I have Air on my face but when I start the Engine the Air on my face goes off.
Trying to find a combination of what suit this issue.
Now I have Learning from Right to Left. (leave the selector set to right, windscreen)
1/ Press the Rear Demister until the you hear the very FIRST FLAP Moving and let it go immediately.
2/ The Vents selection was left on the Far right (Windscreen) then I move it to the Left to the last setting that on you Face ONLY and I do this before the first Cycle finishes then (I think as I might have done of forgot to do this) I then pressed the rear demister on and off again.
Today is the first time I have started the car and went shopping and stops and stated the car 5 times and the Air Con vent selection was Good.
Also I do this
1/ Before you turn the engine off turn off the radio.
2/ Before you turn the engine off turn the Air Conditioner off, then the Fan selector off
Now this is pain in the ars.e but if it works I will continually do it.
I still have a feeling that the leaning process is missing something
