Alarm goes off for no reason - any ideas as to fix ?
XUV
HSV XUV
As thread says the alarm on my VY11 HSV XUV goes for no reason .
any one got a fix or a why ?
I've been manually locking it , so as not to activate the alarm ,
but force of habit , I click the key button and then a few hours later it goes off .
Is there a sensor I can replace ?
PaulSV6
CHE Tuned 156.8rwkw
Castle Hill
VZ SV6 M6, MY10 VE SV6 Sportswagon & MY03 XC SRI
Shock sensor!! or could be a loose wire somewhere.
Did u install urself or did u get someone to do it?
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
my VK used to be bad for going off when harleys or cars with deep exhaust notes went past used to be a little annoying.you may need to adjust the shock sensor if it has an adjustable one.
xtr3
North West Vic
VF Calais V 3.6L
Am i wrong in assuming that the VY reports the location of the alarm trigger on the dash LCD?
I know the VZ does it. Reporting things like Boot or Drivers door.
Wouldnt it be easier to just walk out, unlock the car, put the key in the ignition and start it, then read the reason?
XUV
HSV XUV
yes , passenger doors , is alarm report ,
whuich I gather is rear doors on a crewie .
HSV/Holden fitted alarm .
SMIT
Donating Member
33
Mornington Peninsula, Victoria
VT C2R TURBO 5SP + CRUNCH VE SSV 6SP
not 100% sure with factory, but have you changed the interior light bulb to something different? or have one at all? preety sure they would be part of the trigger system in the door (share same switch, same circuit)
XUV
HSV XUV
Can the alarm be turned off thru workshop diagnostics ?
as i think maybe the locks might be sticking .
scorp
04' VY SerII Acclaim
has it always been doing this dude?..coz with my vy you have to use either the key to unlock and lock or the remote to unlock and lock...otherwise the alarm goes off.. i wasnt sure if it was meant to do this either but never really bothered to find out.
YMY-88U
Project VH SL/E
hey guys ,
remove your clock spring/horn pad on vy and vz's the factory sticker they put on the steering wheel is made from aluminum and after few years starts peeling and conects the circuit for the horn...that is if it just the horn randowly going of for no reason, it happended in my old vy ss
alien
Tullamarine, Vic
03 VY Supercharged 3.8L
Thanks for that.... using the key still sets of the alarm! :mad: Trying to leave a friends house last night at 5AM, trying to be quiet, i figure pressing the button will set off the two horn beeps to unlock it, so i'd use the key, that was good, it unlocked, but as soon as i opened the door the alarm went off! Everyone in her street probably heard it.
Lesson learned, always use the buttons on the key!
