ALDL diagnostics - is OTC 4000 Enhanced scan tool compatible?
lordmuz
2009 MY10 WM Caprice 3.6L V6 SIDI
A question for the diagnostic experts amongst us...
Hey I am trying to get ALDL data from a VN and a VS Commodore. I am using the OTC 4000 Enhanced scan tool.
Is this scan tool compatible with the ALDL data stream of the commodores? I have heard it is. Which software module should be used (would the pathfinder 96 or pathfinder 99 be suitable)?
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
i think you need pathfinder93 or lower and aldl connection cable do you have them.myself ide make a normal DIY aldl cable cost of parts about $5 software is free.must be a good scanner you have $4000 worth
stocky
does anyone know what data cable to use for a VR V8? i dont know the difference between OBD OBD2 etc
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
what you want stocky just an aldl interface for the lappy.just build a 2trans aldl cable cheap and easy work all good too.
lordmuz
I have the ALDL cables for the scanner (both the 6 pin squareish one for the VN and also the OBD2 16-pin for the VS). I've ordered the pathfinder 99 and pathfinder 93 software, so i'll see how I go.
