Side Note,
I also found [in my VE] that the centre output temp was approx. 15deg [in January], based on a ambient air temp of 26 > 32 deg,
The Low pressure side was under 30psi, and the high pressure side was approx. 130 psi,
going by the Pressure-Temperature Relationship reference, it appeared my HVAC was low on Gas,
So I purchased a R134a can, and filler hose, topped it up,
Put the manifold/gauges on it.
And the Low Pressure increased to approx. 38 psi, the high pressure side increased to 165 psi when running.
and the centre vent output temp dropped to 4deg, so its nice and cool again,
[Where I mentioned it in another thread]
I found the location where the refrigerant is leaking,
Its on the high pressure pipe at both ends of the rubber pipe [where the compression fittings are], as I could see the fluorescent refrigerant oil [with a UV torch at night] on the high pressure pipe, as its sprayed everywhere under the harmonic balancer area.
Where I have purchased a replacement manifold, and pipes, just have to do it.
