Alons
- Dec 11, 2017
- 8
- 0
- 1
- Age
- 30
- Location
- Qld
- 2004 vz v6 3.6 alloytec executive
Hey people,
Own a commodore 2004 vz 3.6 v6 alloytec for a few months and can't stop it from over heating. It coused after long drive on the highway (more then an hour), when I'm going into a city or facing with traffic the cooling system is not getting air, can't hold it and overheating - the coolent is bubbeling and then start to overflow.
Steps that have been taken:
1. First mechanic told me the thermostat is faulty so he replaces it and the housings. (was very expensive due to the location of the termostat). Flushed the rad as well.
2. After that noticed that the radiator fan not working (just when I'm turning on the heat AC it's kicking in). Second mechanic replaced the thermo fan switch. Now the rad fan is working when the engine reaches working temp. Although when the car switched off the rad fan stops working. (Coolent temp was 117 at one time, it should keep working even when the engine turned off!!)
When the heat is turned on the car controls the heat, therefor thought that fixing the rad fan will solve the problem but it seems that even if the fan works, the car will keep overheating unless I'll use the heat A.C and let the air in the angine circulate.
After mechanics checks here some more info about my cooling system:
Cooling system pressure is ok, no air in the system, water pump bit noisy but seems to work well (no leaking).
Used to fill 100% red coolent, now mixed with rain water due to constant refill (After coolent got out from the overflow.
System lid looks fine.
Most important thing - No coolent in the oil or oil in the coolent.
Saw some similar essues with the alloytec engine in this forum, but couldn't figuer out what is the next step that should be considered.
Sort of lost with it, will glad to get some help.
