BobT
Has anyone tried the Alloytec on premium fuel? The user manual hints that there might be a performance improvement with the use of premium but no details are given. I suspect there may be more to it than they are letting on.
The Alloytec has a compression ration of 10.2:1. I would have thought that would put it into premium territory. The Merc SLK has a 3.5l V6 with a compression ration of 10.7:1. It runs premium and gets 200kW against the Alloytec’s 190kW. OK it’s a Merc against a Holden but still, with a recalibration of the chip for premium, I wouldn’t mind betting that the best part of another 10kW could be wrung out of the Alloytec 190.
Tuning the engine for standard unleaded is clearly a marketing issue. Un-leaded 6s and 8s is where the numbers are. There is not much to be gained taking on the Europeans. In any case a premium Alloytec would devalue the standard engine just as the Alloytec 190 has devalued the Alloytec 175. I’m sure Holden did not want to release the SV6 but the following that the Ford XR6 got gave them no choice. The XR6 turbo is no problem to Holden. Holden has ample V8s and in any case I’m sure the XR6 turbo is not a big volume seller despite its formidable reputation.
