I wouldn't say they are heavy breathers, if anything the LS series of motors is worse. All engines breathe, it just depends on how well those gases are filtered before they go back into the intake that matters. GM tried to improve the PCV system on the later LS motors by adding a filter system under the the valley cover where the breather pipe comes from.
One reason for increased blow-by may be the use of low tension rings, less friction = less parasitic losses but might = more blow-by in the long run? If you really want to run low tension rings it pays to have a crankcase vacuum system as the vacuum helps to seal the rings against the bore but now we are getting into race car territory.
