aloine 4ch problem?
Mudcrab92
Wycheproof
Vx s 5sp
My alpine 4 channel keeps cutting out at high volume, its not overheating. Ive also got 2 monos. 0gau from battery too boot then a distribution block into 3 x 4gau cables for the amps. Same for the earth. 0gau from seat bolt into distribution block etc. Monos stay playing strong but the 4 channel amp is cutting out. Its running 2 sets of alpine type r component speakers. Also battery is a yellowtop
Tasmaniak
Not a valid input....
42
S.E. Melbourne
www.ranjinstallations.com.au
When does it come back on? Is the protect light coming on? Or is the amp shutting down?(no lights on)
Mudcrab92
Wycheproof
Vx s 5sp
Amp totally cuts out. The blue light stays on but I have to totally turn off the headunit or car to get it back on. Its annoying. All gains are set to 0
aussie4life
Keep It Simple Stupid
Australia
2010 VE International 3.0L
Try disconnecting each rca lead individually. i had a 2 ch amp that was doing something similar. turned out one of the channels had dropped and caused the amp to overload and killed all sound.
Mudcrab92
Wycheproof
Vx s 5sp
All the rcas are quite tight in the connector. They got 0 chance of moving.
Tasmaniak
42
S.E. Melbourne
Start measuring things mate. Check for excessive voltage. Check heat. Check speaker impedance. Lots of things to look at.
Mudcrab92
Wycheproof
Vx s 5sp
speaker all at 4ohm. heat is not an issure voltage might be i dont know..
Tasmaniak
42
S.E. Melbourne
what makes you say heat is not an issue? Not saying it isn't, just wondering what makes you say it isn't.
Mudcrab92
Wycheproof
Vx s 5sp
The feel of the amp is after a few hours of constant music at 3/4 volume isnt even slightly warm. Thats my guess to say its not overheating? My old amp got quite hot on the touch.
