Alpine headunit Brackets
madamd
40
Vr Calais
ok, now i am driving the car around semi in bits, i need headunit Brackets for my alpine cda-9811.....i dont know where my original ones went as i havent seen them since i pulled the hu out of my vs i wrote off about 15 months ago, im just wondering what i should do about making my own, or modifying the original ones
thanks Peter
T
trento
Guest
hi madamd,
I have an alpine unit in my VS, I just modified the orginal brackets that held in the eurovox head unit. Drill a couple of holes that will line up with holes in the side of the unit and lock them down with some screws...prior to drilling the bracket holes you will have to line the brackets up so that they hold the unit in the correct position in the car, but you can test this by taping them on at first and a bit of trial and error with the positioning. :king:
V
vpcrappadoor
Guest
goto a car audio place they should have heaps in the install bays were they install stereos i found a couple there
madamd
40
Vr Calais
thanks for the help, i will try audio place before drilling the old ones.........so its easier hopefully :D
KAL SPL
46
Orange Nsw
www.cardomain.com
Blown VS Calais !!
disconnect heater control rod next to where your left ankle would sit on drivers side , little white clip on swing arm
drop panel below steering column ,3 clips twist 90 degrees
3 screws down driver side of dash facia
drop glove box 1 clip in box at rear right , slide clip out towards passenger side
3 screws down passenger side of dash facia
remove ashtray
remove panel around shifter clipped in only and slide back
3 screws along bottom of center facia panel
unclip facia panel carefully
Unplug the LED for immobiliser (this sux)
4 screw hold dash facia and 1 in AC controls
2 plugs in rear of AC controls + 1 hose cluster
undo 2 Large chrome screws going straight down and console will drop
remove dash facia
2 screws holding deck in
Orange = constant 12V
yellow = accesories
Black = earth
Brown/white = illumination
yellow/red = elec aerial
dark green & light green = front right (DG-)
tan & grey = front left (G-)
dark/black & blue red = rear right (DB-)
brown/black & yellow/blue = rear left (YB-)
There is 3 screws holding the brackets to the deck , if you drill a new hole between the 2 screws that are towards the front of the bracket it will line up with most after market decks and will screw straight in and look stock again.
madamd
40
Vr Calais
installed, i got help from local alpine installer on where 2 drill :)
