nitemares
- Nov 11, 2012
- 14
- 2
- 3
- Age
- 61
- Location
- Buderim, Queensland
- 2007 VZ White Crewman ute.
I have been using the factory Blaupunkt single CD head unit in my 2007 VZ Crewman since I bought the car. I had it modified to accept an old I Pod Classic....worked great.
The door speakers died and I replaced all them with Alpine S-S65 co-axial speakers.
https://www.alpine.com.au/shop/speaker-systems/s-series/s-s65/
Then I wanted a little more punch than the factory head unit would provide. But at that time I wanted to keep the factory look. So in went one of these little Alpine power amps. KTP-445U.
https://www.alpine.com.au/shop/processors-accessories/amplifiers-accessories/ktp-445u/
Then time rolled on and I wanted Bluetooth so I could get Spotify in my car. CD was not an issue...I-Pod not an issue.
So I got an Alpine head unit, a 7 inch touch screen model with a VZ facia and patch lead, iso lead, and steering wheel lead. It went in quite well and works great. The Alpine iLX-702D looks and works well.
https://www.alpine.com.au/shop/navigation/audio-visual-receivers/ilx-702d/
But I have one big issue. Where did the BASS go? The factory head unit, the Alpine speakers and even the little Alpine power amp had heaps of low end grunt.
All I did was take out the old head unit and put in the new one. It has heaps of volume. It is clear and the low end sounds are there...just no punch.
I have read everything...including the owners manual....watched videos....and nothing works.
Have I done something wrong?
I found a good price on an under seat sub-woofer, and grabbed one. An Alpine PWE-S8 arrived today.
https://www.alpine.com.au/shop/subwoofers/compact-subwoofers/pwe-s8/
I have to work Sat and Sun. So Monday the front passenger seat will come out at the sub will go in. I am certain it will all work well together. But my query still remains....where did the low end go? The Blaupunkt had great low end, and was only enhanced by the little power amp and better door speakers.
The iLX-702D has a beautiful, loud, clear sound, but is like the low end just disappeared.
Anybody have any idea if I need to change a setting? I have reset the head unit a number of times and started again. It has all these sound settings and adjustments....none make Odesza sound good.
Your advice will be greedily consumed. Thank you in advance.
