Alternative Fuel Pressure Regulator
MRoberts
adelaide
Vs series 2 ute
VS Ecotec V6 Commodore need to put new fuel pressure regulator on. The correct part is
FPR-161 (fuelmiser) this part is out of stock everywhere . I found one on some dingy site but they want $258.00 that's without postage - everyone else is charging $150.00 but out of stock. maybe they dont make the part anymore? I'm not getting ripped off bugger that !
Does anyone know of another brand or alternative that will fit the ecotech v6 that has a more realistic price . do Bosch make something etc..
cheers
the_boozer
no more VK
51
Shitsville Morwell
hilux
go and see if you can find one at the wreckers otherwise pay the money. the joys of old cars its only going to get worse as time goes by
vs-lover
VS S2 Calais, VS S2 Exec Wagon, VS S2 Acclaim
Couldn't agree more..................UPI in SA have just sourced a few more VS's to their Gillman stockpile, but these will only hang around for 3 months until they meet their fate with the Excavator in the tear down shed at Elizabeth. It's all VT's and VX's at the moment as VS is rapidly going into decline on the roads. Sadly every model will go through this phase and that's when prices for certain parts go through the roof.
In saying the above you should be able to get that regulator Secondhand off of a newer VY model and avoid paying stupid prices at the new parts counter.
losh1971
North Tas
VE Series I SS Ute
The VS reg is VS specific, unfortunately later model ones won't fit. Like said you have two options pay the stupid price, if it is even the right one or go SH. They have been unavailable new for a few years now.
woteva
NEED 4 SPEED
Adelaide S.A.
Or there might be a third option to change to a later fuel rail ?
I have a VT ecotec engine here. Will have a quick look later.
losh1971
North Tas
VE Series I SS Ute
Yeah there was a thread with a bloke looking at that option when he couldn't get a reg. The thread would be two years old so time consuming for me to go searching.
two-bit
old enough to mang better
VS S series II
the vs regulator has a little tab and screw that holds it in place, the vt/vx/vy is a push in style.
i am not sure if there is a pressure difference or flow difference between models
you could in theory swap the fuel rails over and just change the rubber fuel hose the goes from the fuel rail on the motor to the steel fuel lines on the car. the vt/vx/vy lines are different lengths possibly different diameter, but some fuel hose and efi clamps should solve that problem
vs-lover
Oh ok, didn't know that, but I guess there were quite a few running changes that were made along the Ecotec's lifespan. Manifolds were another one of those changes, so thanks Losh for bringing that one to my attention. I've never had to change one of those.
losh1971
North Tas
VE Series I SS Ute
I figured you probably haven't had to swap one VSL. Might be worth a sneaky trip to UPI and grab a couple to stash away, good backyard wrecker should have a couple in stock..... :rolleyes:I tried searching for the two year old thread from another member and what he ended up doing but I need more specific search criteria to nail it down to 6 or 7 results not 100.
vs-lover
Absolutely Losh !! all good parts stockists must do that. I'll get to that right away.;)
Must get another 8 bent cars to stick into my front yard as ornaments as I seem to have a lot of room there at the moment after the last 10 being removed by council.
