Alternator noise
hako
Donating Member
81
Toowoomba SE QLD
VS11 BT1 V6
That will be the front bearing - it is replaceable for under $10 but you need to remove the rotor and front pulley to fit it. Take your time and it can be done.
Good Luck.
accentstencil
72
Caboolture South, QLD
WH II Caprice, 5.7 2018 Equinox LTZ V
My alternator is making a grinding/whirring noise, could it be a bearing? If so how do i replace it?
It probably is a bearing. You will need to pull the alternator apart to replace the bearing(s). A very simple job really. You will probably need a puller to get the bearings of the shaft.
accentstencil
72
Just took the belt off and spun all the pulleys, it's the tensioner pulley! Is there a bearing in that or do i need a new assembly?
You can replace the pulley for around $30 from Supercheap, Repco, Bursons etc. The bolt that holds it on is left hand thread (turn it clockwise to undo it.)
