Alternator problem?
Holden_Babe07
34
97 VT Acclaim
Hey guys,
Just have a question. I've got a VT and the other day after work my car wouldn't start, I got it jump started and it was fine, drove it around the same day and it had started fine a few times after that. But that night, it had to be jump started again, and now everytime I go to start it, it won't. I had to jump start it last night, but as soon as I turned my lights on it died again. Someone told me it could be the alternator? Just hoping it is not going to be too much to fix?
Anyone know if it sounds like it is the alternator? Or just the battery?
Niper
VX 5.7 A4
It sounds like an alternator
do you see a battery light on the dash when you drive it
Holden_Babe07
34
97 VT Acclaim
No battery light so thats what makes me think it's the alternator.
Not looking forward to the cost to fix it.
Niper
VX 5.7 A4
If you have a volt meter you can test
see the voltage of the battery with the car off it should be around 12 volts if it is lower mabye your battery is dead
Then see the voltage with the car on it should go up to 13 or 14 volts if it doesn't that means your alternator doesn't work
Holden_Babe07
34
97 VT Acclaim
I'll ask my mates and see if any of them have a volt meter.
Thanks for your help!
TrikkBen
I'm Back :D
SE, Vic
www.asroilpans.com
BNR32
Sounds like your battery is just too old or been drained to much to charge properly again...
Or
A main problem with the alternators not charging the battery is the Regulator, the brushes wear out and stop the alterntaor from charging. From my memory the Regulator needed is an RE60 type to suit bosch.
That may be the problem..?
Ben
Holden_Babe07
34
97 VT Acclaim
All fixed!
It was my battery, not sure why the light didn't come on though. Got the mechanic to check my alternator though and that's working fine.
ryno_vrx
Donating Member
Mirani
VR HSV enhanced Berlina
sounds like a problem i had, thought it was the battery to but turns out when the car wasn't running the alternator would drain the battery
MADVRSS
vr ss
The light will only come on when the alt is buggerd . because it stiil has a charge flowing in the alt light wont come on
