Alternator Whine (rear speakers only)
nickwontlose
www.isohunt.com
97 VS Executive
I have noticed issues with alternator being posted already and have tryed all the suggested solutions in them. The thing about my problem is the whine is only comming out through the rear 2 speakers, when I unplug the amp running those speakers, the problem is gone. Thing is, i've tryed 3 different amps, 2 different speakers, changing the grounds, and still I get this noise. Any ideas??
holdenboy
Custom Car Stereo Systems
42
Nelson Bay NSW
VR Wagon
Simple solution.....run the rears off the head-unit ;)
Seriously, you may need to look at the power/RCA side of things......do you run any other amps off the same power cable? RCAs?
holdenboy
42
Nelson Bay NSW
VR Wagon
Do you have another amp/power cable in the car?
If so maybe try using that power cable to power your rear speaker amp. If that dosent work then try using the RCAs off the other amp....if this set is running a sub then you may have to turn off the LPF on the head-unit or swap the RCA over.
What head-unit are you using?
nickwontlose
www.isohunt.com
97 VS Executive
sorry i made a mistake, i'm actually running 2 amps both off the same power cable 1 for the sub 1 for the speakers, i will try swapping the rca on the head unit now
holdenboy
42
Nelson Bay NSW
VR Wagon
Yeah that might be a good idea......you still might have problems with the power cable etc, as the noise is cut from the sub by the LPF.
Head-unit brand?
nickwontlose
www.isohunt.com
97 VS Executive
ok so i just changed it over then, it actually made the whine louder, like twice as loud.
brand is pioneer
holdenboy
42
Nelson Bay NSW
VR Wagon
Ahh, could be the earth fuse inside the head-unit then.
nickwontlose
www.isohunt.com
97 VS Executive
true. I dno what that is lol
I'm prolly jst gonna take it to the shop, i've had it with this problem
holdenboy
42
Nelson Bay NSW
VR Wagon
yeah, its something you dont wanna mess with if your not too confident in pulling apart the stereo.
