Alternator
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by Don123, Nov 23, 2013.
  1. Don123
    Don123 Guest
    Hi all. This afternoon when starting my car ( Holden VP) it wouldn't start and just made a clicking noise as if the battery died but the battery light on the dash didn't come on. I called the NRMA, the guy gave me a jump start and then he checked the alternator and it showed a charge of between 10 and 11.5 amps, he told me that my alternator is not charging and that I need to replace it, but he also couldn't understand why the battery light on the dash didn't come on. This morning on the way to work I noticed that the light were dim and when using the indicators the radio won't play. My question is, is it the alternator or is it my battery? should I just buy another alternator and put it in? why the battery dash light didn't come on? This alternator is about 11 years old. Thanks.
  2. BOOST666
    BOOST666 Classic not plastic
    NSW Central Coast
    '79 VB SL/E 253, VY SS II
    I think you mean 10-11.5 volts?
    I would try replacing the voltage regulator first, 9/10 times that's the issue with these old alternators, the brushes wear out. You can get a new aftermarket voltage reg for less than $50.
  3. Deuce
    Deuce Super Stock
    '94 VR SS V8
    my alternator packed up 6months ago. I got a set of brushes for around $10 and rebuilt mine, I've had no issue's since!
  4. Don123
    Don123 Guest
    Yes, 11.5 volts. Is the voltage regulator inside the alternator or is it a different part? How do I know if it's the battery or the alternator?
  5. BOOST666
    NSW Central Coast
    The voltage reg is the black part that attaches to the back of the alternator(external) by 2 Phillips screws, if the charge rate is 11.5 then it's a safe bet that your alternator is the problem, also when the engine is running the alternator supplies power to all electrical components not the battery, so if you're having problems with the radio or dim lights that's another indicator that the alternator is your problem, just get a voltage reg and fit it, it's a very basic 5 min job, just make sure the battery is disconnected when you do the job, and as mentioned they are very cheap. Let us know how you go.
  6. _R_J_K_
    _R_J_K_ Well-Known Member
    Zenki S14
    This. Should be well over 13v for a healthy alternator.
  7. Tasmaniak
    S.E. Melbourne
    New brushes for alternator, rebuilt is not!
    Bearings, diodes, windings cleaned up, brushes, regulator... that makes for a rebuild.... and a coat of paint :p
    To the OP, yes, your alternator is kaput. The charge light usually only comes on when there is no connection between alternator and battery. Most likely as simple as a set of brushes, if your not skilled with a soldering iron, just change the whole reg assembly.
    Depending on how long this has been the case, your battery may or may not be toast. I would definetly get the battery checked after getting the alternator repaired. While it may start the car, I wou;dn't be surprised if it wasn't capable of holding it's charge for very long anymore.... but who knows... I've been wrong before once.
    Just once :p
  8. Tasmaniak
    S.E. Melbourne
    Output for a healthy alternator should be in excess of 14Volts at the battery and a couple of points higher at the alternator itself. Usually 14.4 at battery and 14.5-14.7 off the back of the alternator
    Just once :p
  9. DJ_Cosmic_Fire
    DJ_Cosmic_Fire smarter not harder
    South East Queensland
    VP S-Pack Oct '91 - VT SrsII Wagon - VE SV6 SrsII
    Get a brand new oem standard alternator for 160 such as Jaylec, shelve the current one as alluded to it can be rebuilt, & it's always good to have a spare heart ;)
    Generally after all this activity it is best to replace the battery, as the current one will have been through alot of strain - keep that as well, car batteries come in handy for heaps of things >
  10. Deuce
    Deuce Super Stock
    '94 VR SS V8
    Sorry mate, I meant I rebuilt it (as in re-assembled it) with the new brushes. I did not mean that I did a full overhaul and rebuild as you have described.
    And yes, Coat of paint or a polish up of housings is a great idea while it is apart :thumbsup:
  11. VR38
    VR38 Well-Known Member
    VB SL/E
    Sounds to me like the charge wire on the back of the alternator (that runs to the battery) has burnt out and needs replacing.
  12. Don123
    Don123 Guest
    Thank you all for your input. This morning ( Sunday) I had the battery and alternator checked, the battery is okay but the alternator was charging at about 11 volts, I pulled the alternator out and the voltage regulator was definitely kaput, but the alternator itself didn't look too good either, anyway I ended up getting the whole thing new and all is okay now. Thanks Tasmaniak for explaining the reason the battery light didn't come on, it make sense. My old alternator lasted from March 2000, almost 14 years, however I thought it should last a lot longer.
  13. wortus
    wortus Active Member
    An auto elec will only replace what is broken when doing a reco, with the exception of bearings which are replaced. They won't be putting in new diodes etc unless they are stuffed. likewise if the slip rings are worn but not worn out they usually only machine then. 9 times out of 10 with these alternators it's worn out brushes.
  14. wortus
    14 years is pretty good, how many K's? When I had a VN I replaced the brushes twice, the bearings once in 10 years and 130,000km.
  15. Don123
    Don123 Guest
    I couldn't tell you how many Ks as I don't remember and I didn't write it down on the receipt at the time, but this car is doing a lot of small runs with engine stop start, so I guess that would be many many starts. I change the oil and filter myself twice a year regardless of Ks. I know people who had cars for 30 years and never had to replace alternators.
  16. Tasmaniak
    S.E. Melbourne
    While I completely agree as these are not usually components that wear out over time... a new set of brushes does not make a reco..
  17. Don123
    Don123 Guest
    Should I just put the old alternator in the bin, or do you think it might be worth anything? The local auto electrician doesn't want it.
  18. Tasmaniak
    S.E. Melbourne
    I'd probably dump it...
  19. wortus
    Keep the old one, get a new set of bearings and brushes for it and keep it for a spare.
  20. wortus
    Agreed but an auto elec will machine the slip rings, wack in some new bearings and sell it as reco exchange. The one around here, the regulator is extra on top of the reco exchange price hence why last time I got him to put new bearings on the rotor and soldered in a new set of brushes myself, cost about $40.00 and was working fine when I sold it years later.
