the guy im buying them off recons the audio pipe GD3001 2000 WATT MONO BLOCK DIGITAL AMP
OUTPUT 1000 WATTS RMS @ 1 OHM (FULLY 1 OHM STABLE ) CERTIFIED BY IASCA
TESTED TO CEA (USA) STANDARDS, DISTORTION LESS THAN 0.5% THD.
MASTER SLAVE FUNCTION AT 4 OHMS. SIGNAL TO NOISE RATIO 60dB.
RCA INPUT SENSITIVITY 0.2 - 5 VOLTS, INPUT IMPEDANCE 20 K OHMS
LOW PASS FILTER 40-250 Hz / 24dB OCT, SUBSONIC FILTER 10-50 Hz / 24dB OCT.
FREQUENCY RESPONSE 10-300Hz. / 4G INPUT
the subs are 750watt rms 1500watt max
any help
