Amp Keeps blowing Fuses
D
Darkwander
Guest
I have installed my amp and as far as i know it is right , however everytime the head unit it turned on it blows the little fuse on the side of the amp. Does anyone have any ideas why it might do this ?
Julie
moderator- for now anyway
Western Sydney, NSW
Blown VT Calais 355 + SC VY V6
Check that its grounded properly and look for shorts :)
D
Darkwander
Guest
Both the grounds are fine , i connected a 12 volt light to the power and the ground wires and it lite up both the times. When i do put in the new fuse and turn it on the only spark comes from near the power lead, But this is where the fuse is so i think it is that....
Jimbo
Bit confused,... you connected a 12v test lamp, (one end to earth/ground), and the other to:
1 - the positive of the amp and your globe lit up
2 - the ground of the amp and the globe lit up
Is that what you're saying ?? If so, it doesn't sound right to me.
Jim.....
D
Darkwander
Guest
Hey all , i have taken the amp back and they tested it. The Amp was faulty and had burnt out, they replaced it and it is working now..
D
Darkwander
Guest
oooo , she isnt going anywhere anytime soon , i have always mounted them there, havnt had a problem , there are wholes , decent size wholes in the parcel shelf above the amp that should help with the heat..
Julie
Western Sydney, NSW
I am with kalspl, don't leave it mounted like that unless u want it fried. Most manufacturers specifically state not to mount them upside down, and if you do your warranty wil be void. Bad idea........
KAL SPL
46
Orange Nsw
www.cardomain.com
Blown VS Calais !!
Which side of the amp are the heat sinks on now ? the top or the bottom ?
They are designed to disperse the heat , all the heat in your amp now is staying in the circut board , BAD IDEA :)
Bax
Projecting
40
QLD
Nothing
Heat rises with air..
As for metal I'm fairly positive the circuit board will be as hot as it would be normally. As long as there is oxygen getting to the Heat Sink. Thats all it needs.
Heat- goes into the metal, works its way spreads out over the metal, large surface area. More chance for cooling.
