Amp powerage
Matty14
Frankston (is a hole)
Vu ute 5speed 3.8L
I have a full sound system in my ute which has 2way speakers 350w and a sub 1200w and a amp 800w and it runs fine
Is it worth getting a bigger amp or not?
I'm looking at a 1200w class D amp
StoneX
41
Hastings
VE Calais-V 6.0L
If it runs fine, no.
Can you tell us model numbers and RMS/continuous power ratings?
Tasmaniak
Not a valid input....
S.E. Melbourne
www.ranjinstallations.com.au
Yes on all of it mate.
Matty14
Vu ute 5speed 3.8L
GM-6500F. Amp. Its 760W not 800W
Maximum Output Power: 4 x 190W (4 Ω) / 2 x 380 W (4 Ω bridged)
CEA 2006 Power: (THD + N = 1%) 60 W RMS X 4
Continuous power output: (RMS)• 14.4V (20Hz-20kHz/4Ω): 4 x 60W / 2 x 180W (bridged)
• 14.4V (20Hz-20kHz/2Ω): 4 x 86 W
Load impedance capability 4Ω
Frequency response(+0dB , -3dB) 10Hz ~ 70k Hz
TS-WX303. Sub
Maximum input power1.200 W
Nominal input power250 W
Frequency response10 - 220 Hz
Sensitivity (1W/1m)98 dB
TS-A1605C. Speakers
Maximum input power350 W W
Nominal input power60 W W
Frequency response34 Hz to 32kHz Hz
Sensitivity (1W/1m)90 dB dB
vongy10
Gunnedah
CV8 Monaro V2
That amp powers those speakers fine. It has enough power for the sub for everyday listening but if you want to have it to be fully powered then look for an amp that puts out 250rms or more.
So you don't need a bigger amp, you can get another to power the sub but that's up to you.
vongy10
Gunnedah
CV8 Monaro V2
How? There's 5 spots I can think of in a ute. Under each seat, behind each seat and between the seats above the center console.
Matty14
Vu ute 5speed 3.8L
Most of those spots are stupid, I have my amp behind the drivers seat only cause the sub could only go below it
I'm only having pioneer so it's the one I have at the moment or
GM-D8604 1200W
4 x 200 W (4Ω)
4 x 300 W (2Ω)
2 x 600 W (4Ω bridge)
CEA 2006 Power (THD + N = 1%)
4 x 100 W (20 kHz - 20 kHz / 4Ω)
2 x 300 W (1 kHz / 4Ω bridge)
4 x 150 W (1 kHz / 2Ω)
75 dBA (ref: 1 W into 4Ω)
Continuous power output (RMS)
4 x 100 W (20 Hz - 20 kHz)
4 x 125 W (1 kHz / 1Ω)
2 x 250 W (1 kHz / 2Ω bridge)
Frequency response10 - 50000 Hz
Distortion< 0.05 %
S/N ratio> 95 dB
LPF40 - 500 Hz (-12 dB/oct)
HPF40 - 500 Hz (-12 dB/oct)
