Just finished hooking up my gear and went to test it but the amp did not come on.......it was in diagnostic mode. I unplugged everything except the power supply to the amp and this time no lights came on at all. When i tried to plug an RCA plug into it the diagnostic LED came on.
I think it's a power issue though because it does not go into 'power' mode with only power, ground and remote plugged in.
If i put a multimeter on the power and ground cable (not plugged into the amp) i get about 12V. When i plug them into the amp and measure across the amps terminals it is about 6V......dodgey fuse maybe???
And also is the remote trigger 12V as well.......haven't measured yet but not sure what it is supposed to be
EDIT: when i used the multimeter it was more like 11.98V
