AMP troubles
Discussion in 'Electrical Wiring / Questions' started by juzzteq, Jul 29, 2009.
  1. juzzteq
    juzzteq RedLine Racing
    VT commodore spac
    Hey all,
    when i get to a certain volume level my amp seems to cut out?
    is this a wiring problem or what ?
    any help appreciated.
  2. DVS
    DVS D̮̯͓͂͌ͤͬ̌ͣ̈ͧͩ̃͐ͩ͛̔̀͛̑ͯ ͎̞̜
    VT V6
    Is it cutting out on high volumes ?
  3. juzzteq
    VT commodore spac
    ye man its cutting out on high volumes :(
  4. shiftySLE
    shiftySLE The Lion will never Die!
    VH SLE, VZ Acclaim
    could be overheating, is it mounted right, not upside down or covered up or something is it, what amp, cheapo or decent.
  5. juzzteq
    VT commodore spac
    nah its mounted 100% correct and its not overheating, its a kicker 900watt monoblock
  6. DVS
    VT V6
    Well usually this happens because the amplifier is under powered. What are the ratings of your Subs and the amplifier ?
    Maybe you could get this thread moved to the Car audio section for more reply's :)
  7. Maci
    Maci New Member
    Goulburn NSW
    2003 Holden Statesman
    its either not recieving enough power (too small of amp wiring from battery or insufficient battery power, do your headlights/instrument cluster lights dim?) or as DVS said its being drawn on too hard, if you're running 2 subs, disconnect one and try it at the "cut out" volume.
  8. Fonzie
    Fonzie Just lost the game.
    What he said.
    If it's a lack of power issue, you'll need to upgrade the big 3... Or at least some of it. Battery, Alternator, Wiring. Having the battery closer to the amp will help also...
    Or you could go the cheap option and buy a capacitor... :bang:
  9. VPplayer
    VPplayer New Member
    Melbourne, bayswater
    VP Exec
    I set up my amp and sub last week and the exact same thing is happening to me.
    Running a 15" Pioneer sub - 1200 watts 450 rms
    And its running off a cheap asian amp off ebay ( got it free ).
    Turn it up to high and it cuts out. changed the earth wire to a thicker one. Running a 4 gauge wiring kit so i dont think thats the issue.
  10. Fonzie
    You're probably overloading the amp... And again, the battery and alternator need upgrading. You'll probably find it can go louder with the engine running, and hence the alternator pumping charge into the circuit.
