amp upgrade
garfa
37
SE Victoria
VY SS
anything from jaycar's bigger sized amps will be able to run them or a pioneer from JB or something of the sort. you will probably get a good deal from jb if you dont want to import. if you want to import then i can tell you a few sites and tips.
G4orce
HSV Owner
Melbourne SE Subs
www.myspace.com
Vy Senator Signature 5.7lt auto
For your subs I would just go a 400 or 500 watt Mono block amp. Make sure the amp is rated at 400 or 500 watt RMS or else it will not do as expected. I looked at your spec for the subs and they are only rated at 200RMS each so 500 may even be too much for your subs. I would recomend going to a JB HiFi and asking them for a mono channel amp that puts our 400 - 500 watt rms and they will do you a good deal. I would posibly go Cadence, pioneer or if you are willing to spend a little more go Kicker.
Hope that helps.
Good Luck
lieos
what ford i didnt see it
sydney
go for the 1800w kenwood mono it does 500wrms 4ohm and 900wrms 2ohm my m8 has this amp and it goes good and they are rrp $599 so u can obviously get it cheaper then that
