Nah, the buzzing caused by the blown RCA ground fuse wouldn't change... Once it's blown, you have the noise. It might be something else causing the noise if it's changed over time.
If you really want to check if it's the RCA ground gone you can do the following (this is for anyone, not just you, padrickz):
- Slide your head unit out of the dash
- Find where the RCA's are plugged in (leave them plugged in)
- Grab a bit of wire (strip both ends)
- Touch one end of the wire you the head unit's metal shell (as that is always ground unless a whole bunch of earth tracks in the head unit have fried)
- Touch the other end of the wire to the visble metal on the RCA connection (the outside ring that you can still see when the RCA's are plugged in is the ground, the sound travels via the centre pin)
- Start your car and play some music
If the whining/buzzing sound is gone, it means the RCA ground fuse is blown. If the whining/buzzing sound is still there, the problem is elsewhere.
