ANOTHER brakes question
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by Leebo, May 13, 2009.
  1. Leebo
    Leebo New Member
    89 VN
    Hey guys are the brakes calipers on a VN V8 or SS different to the regular V6 ones?
    I know the fronts are 270mm single pistons on the 6r's
    but are the 8r's 290mm with **** piston(s)?
  2. pow3rslave
    pow3rslave DoNothing Member
    eastern subs, vic
    VP 5.0L
    only the vnss group a had twin fronts.
  3. Leebo
    Leebo New Member
    89 VN
    So does a 290mm disc fit straight bolt on into my standard v6 front calipers?
    or will the bracket not reach the holes?
  4. Pub247
    Pub247 Well-Known Member
    Melbourne S.E.
    Ford Fairmont
    no you need the calipers to match
  5. Leebo
    Leebo New Member
    89 VN
    makes sense but putting SS brakes on a V6 would not make much difference would that be a fair comment?
    as apposed to 330mm HSV brakes etc.
    Should i see improvement in standard size slotted all round?
  6. Not_An_Abba_Fan
    Not_An_Abba_Fan Exhaust Guru
    Bunbury, WA
    Strange Rover
    It will make a difference, but the question should be will you notice it?
    Upgrading the rotors to slotted and having better pads will be noticeable.
  7. Leebo
    Leebo New Member
    89 VN
    Yeah just the original size but in slotted if I'm going to do it
    I need new disc anyway so i wouldn't get new original ones that would be stupid.
