Took out the windscreen today so I can start to get the dash mounted properly. Looks like it is going to fit pretty well. Width is the same but height may be a bit different. Just want to get it running first. Got the new fuel lines run with a return line. Today I fitted the MAT sensor from the VR along with the 2 coolant sensors. Fitted a VP TPS to the VT trottle body. Got a VR regulator and screwed into VT alternator so i don't have to change the plug on the loom. Still need a VR ECU. I have the BCM from the VR in and the wholde VR loom in. Checked and have ignition, all lights, etc. Next is the radiator so when I get an ECU I can hopefully start it up. Any ideas on a knock sensor? Should I use the VR one as I am running the VR ECU? Decided it's going to be a bit of a hybrid.
So far i have used
VT Ecotec
VR dash, loom, fuel tank, crossmember, suspension, brakes and interior
Patrol turbos
VP radiator
