You're going to get a bit of a laugh out of this.
So i haven't started my car for about a week (battery was flat so it was on trickle charge) anyways, battery finally was charged,
So i started my car (only the exhaust on the passenger side is loose), Well i notice water leaking out on the floor so i assumed i hadn't tightened one of the hoses again.
Well it was leaking out of the drivers side of the engine just behind the power steering pump i assumed,
As an after thought i checked the oil (i did a full service on the engine while it was out)
Well now i have water in the oil which wasn't in the old black oil, which was one of the things i checked. So i am going to assume that bolts have rattled loose holding the heads down or i have done a gasket.
Could my weekend get anymore worse? So now am i going to have to pull the heads of this new motor?
EDIT ; the only thing i did was finger tightned a jack against the exhaust headers and the wall of the car and started the motor. could this have caused the heads to shift?
