Any videos of a stock 5.7 vs 6.0?
Discussion in 'VE Holden Commodore (2006 - 2013)' started by freefallin, Jan 26, 2014.
  1. freefallin
    freefallin Member
    UAE
    VY Berlina / VZ SS LS1
    Like a VY or VZ LS1 5.7 vs. an L76 or L98 6.0.
    Searched on youtube but couldn't find any.
  2. 'ssv'
    'ssv' Member
    VE SSV MY9.5 M6 UTE
    What is it your wanting to see?
  3. slepar
    slepar omg duz it like...dose??
    vn ss
    If your wondering what would win I can tell you the 6.0 will.
  4. uniacidz
    uniacidz Harden the Frak Up
    Sideneee
    VE Berlina
    Stock for stock
    Engine more advanced
    Better driveline.
    Better mapping
    6.0L for the win
  5. Senator829
    Senator829 Member
    Nth Coast NSW
    VS S2 HSV Senator & 2012 RG Colorado LTZ
    Having owned a SS with a LS1 and a L98 I can tell you hands down the L98 will win. The LS1 in stock form has no balls to at least 3000rpm and up where the l98 had torque from down low. You also have to consider the chassis. The VE despite being heavier put the power to the road so much better the VZ I had. Having driven other ls cars, apart from the ls3, my pick is the l98. It feels much better to drive then the ls2 and the l76
  6. VTSSLS1
    VTSSLS1 New Member
    brisbane
    VT SS LS1 A4 227rwkw
    I agree, compared to my old LS1 the L98 is 30ish kw down on power, and is in a heavier car, but doesn't seem much different, which I put down to the increased bottom end torque and different auto gearing (even though the diff ratio is higher). More potential from the L98 too, with the same mods my LS1 had it should make 30-40rwkw more.
  7. freefallin
    freefallin Member
    UAE
    Ok guys! Bringing this back up.
    So in a race between a stock VZ 5.7 and a VE 6.0...the VZ would loose...miserably. Ok that's understood.
    What about a race between a VZ 6.0 vs. a VE 6.0. Who would win? And if its the VE, which logic dictates, why?
    Aside from the transmission and the axle ratio and the computer...why would the VE win?? They both got the same engine, and the VZ is lighter!
  8. VS-S
    Just saying the VZ 6L has the LS2.
  9. uniacidz
    Sideneee
    VE Berlina
    You already said it, the transmission and mapping.
    Its how it puts it down on the ground
  10. freefallin
    freefallin Member
    UAE
    So you are saying if the VZ 6.0 was tuned and had, hypothetically, the exact same transmission as the VE 6.0, it would either be EXACTLY as fast as the VE or, due to it being lighter, faster than the VE...correct?
  11. uniacidz
    Sideneee
    VE Berlina
    Doesn't matter, they are built differently with different transmissions etc etc
    Stock for stock, VE SS would win.
    Sent via HTC Velocity + [HolicsROM v1.3] [SWEEP2WAKE]
  12. freefallin
    freefallin Member
    UAE
    I was hoping you would be able to break it down. Obviously it is built differently, but what part/s of the build is it exactly that make it faster.
    Nonetheless, still appreciate your input mate!
  13. Senator829
    Senator829 Member
    Nth Coast NSW
    It's also the chassis and it's inherent grip. My vz ss was was no where as planted or solid on the road as the ve. Driving in the wet showed this more. The ve had more grip and could put the power to the road more effectively
  14. WazzaVN
    WazzaVN Wazza VN
    VZ 6ltr ute, VP Calais and HJ Prem
    They both have the same manual trans. Ve has 10 more kw and 20 more nm. I've had a few red lighters with some ve's. Won a few and lost a few. Who's to know which one is stock though? Lol
  15. freefallin
    freefallin Member
    UAE
    Doesn't that just mean its got better suspension
  16. mpower
    mpower Well-Known Member
    The VE also has a more advanced traction control system meaning you can push it harder and the computer will compensate for your minor stuff ups.
  17. Ian Johnston
    Ian Johnston Active Member
    Mount Gambier, SA
    2015 Subaru Forester, XR6 turbo ute.
    VZ 6.0 isnt an LS2 unless its a HSV. VZ LS2 will eat all of the others you talk of.
    Some of the differences you ask about are cylinder head design better on the VE, compression ratio a bit higher, cam lift, inlet manifold flows better etc.
    Its an improved engine to the LS1 in most areas.
