Anyone know how to stop the Exhaust shield from rattling on startup?
fuzzy2308
Plastic datsun
get a mate to push on it while you start the car
Torquative
Sports Economy
VE SV6 3.6L SIDI 6sp
this topic has been covered in great depth elsewhere, no its not as easy as tighten the bolts and nuts because its a poor deisgn to begin with.
My solution was to remove them, as I type there sitting here next to me.
The new problem being their more of a bash plate protection shield then a heat shield and Im worried about damaging the exhaust pipe now, so Im going to source some high temp exhaust wrap (off ebay about 80 bucks) to wrap around the exhaust first then re-bolt the shields back on
thebulk
Quoinsland
09 VE
Thanks Torquative, can I ask how you remove them, I did a search to try to find other threads on this and can't find anything - I may well be not very good at it.
Just wondering if you could tell me how you access the bolts to remove the sheilds and where about's they are.
Thanks again
Exidor
I come in peace.
Earth. For now....
Used Martian spacecraft
The usual reason they rattle is because over time they fill with
small stones etc.
10 metres of exhaust wrap (5 per side) will do the trick.
Make sure you replace old material.
Easy to remove, get under the car and have a look!
VT Berlina 07
15.37 @ 147 KPH
Sydney, NSW
96 EF2 Futura I6 Auto
Torquative
Sports Economy
yeh basically climb under and have a look!
It runs roughly in line with the front wheels and heads towards the engine for almost a meter, you will see it.
From memory 10mm socket does the trick, might be as small as 8mm though.
mattvz
Northen Adelaide
2005 VZ S Ute
Do a search for exhaust rattle or something like that . We covered this before .
BTW mine have never made another noise again after I removed the shields and wrapped them , then replaced the shields .
