Anyone used Aeroflow fittings?
MILD
NE Vic
VN Calais - 355, Powerglide, 9"
Specifically the tube to male AN adapters?
My trans cooler lines are a bit weepy (doesn't matter what I do to fix it) so I am looking at using either Russell or Aeroflow fittings. The Aeroflows are a **** load cheaper per fitting and compatible with the Russell Twist Lok hose that I'll be using.
As I understand it, I can use the Aeroflow tube to male adapter to make it play nice with the -6 hose ends.
Anyone done similar? Does it work well or is it a recipe for disaster?
383 hatch
41
Cowes, Phillip Island
I've always used Speedflow and never had a problem with them. You get what you pay for, if they're cheap you will more than likely find they're chinese. I've used Speedflow tube to AN adaptors on my fuel lines and they have worked fine.
OFF T4P
Donating Member
townsville
383 HSV GTO coupe & vk ls1 turbo
+ 1 for speed flow or earl fittings are pretty decent also.
