are 20'' rim legal on my VT 97 Commodore in nsw
20'' rim on VT yes or no
  • Total voters
  • Poll closed .
john369
mildura
VT commodore Club sport kit
just purchased a VT with 20'' rims some say I con not register the car with these on it
aussie7
51
VR SS
If I remember correctly you can go 1" wider and 2" bigger diameter from standard wheel size
Anything bigger will require a mod plate
sleepa
Shiny...
2010 VE SS Sportwagon, Audi A4, Combo work hack
Did you get an engineers report with the car for the wheels?
Or you could just change to stock rims for the rego to make it easier for you
wikky
Here
VZ SSZ
Your Poll is for opinions. You want facts. Thread fail.
Daggy082
Maroochydore
VY 3.8
Just go to the nsw transport website and check out the modification guide. No point on getting peoples opinions cause they are not always right. Up here in qld we can put any size rims on as long as the overall tyre diameter is no more then +15mm or -26mm.
Jesterarts
Your freedom ends where mine begins
2010 Nissan X-Trail ST-L
1. There is no 2" rule. Its all about rolling diameter and I'm 95% sure you can only do 15mm more than biggest factory fitted to model.
2. There isn't a 20" tyre in the profile you will need that will have the correct load rating on it.
3. Tyre cannot foul any body parts including inner guards when it's turned from lock to lock. Haven't seen a single VT with 20's that manages this.
Short answer, there isn't any way you can legal put 20's on a VT - VZ that doesn't involve getting it engineered.
GEN3RATD
100% Teflon
Cannington, WA
VE Maloo
ive got 20s on my VX SS
and ive got 245/30/R20s and they make the overall rolling diameter 11.8 mm bigger then normal (from memory, i think thats fine?)
the load rating of my car is minimum of 93V, my tyres are 97W.
and lock to lock i dont scrape. at all.
soop
Banned
Smithton, Tasmania.
2003 SS Commodore Series II
jesus tap dancing christ, go to the vicroads website and search it.
Fairly sure its 20% larger then the largest factory fitted wheel.
VT being 17x7.5 means you could probably at a rough estimate go to a 19x8 and get away with it. But do your maths properly.
hakhawk
smooth moderator
Staff member
