vc commodore
- Jun 18, 2014
- 10,701
- 12,573
- 113
- Location
- Like the Leyland Brothers
- VC, VH and VY
No you're incorrect. TTY are brought to the point of yeild where they retain elasticity this is how they clamp.
Look up the specs on Toyota 4cyl head bolts from about 2002 to 2012 they have a max length spec.
So they're reuseable even though they're torque to yeild.
When a bolt is brought into the yeild zone which is a large area on a graph it will strech a little and the yeild zone will change next time it is used. It's not plastic deformation that only happens if you exceed the elastic zone of the yeild curve. When this happens the clamping force will drop slightly before shooting up. This section where the bolts force shoots up is the plastic zone where it's about to break.
You obviously don't fully understand torque to yeild bolts.
TTY bolts are single use bolts and single use only...If you choose to use them a second time, do so at your own peril....Oh and any mechanic that reuses a TTY bolt on a paying customers car, shows they are shonky...
To answer the OP's question...No they aren't a single use bolt...Who ever touched those bolts last either didn't do them up properly, or has cross threaded them in some shape or form
