are vr/vs abs type master cylinders interchangeable?
tim_pato
Tamworth
daily-5.0 5spd vr ss clubodore, project-74 lh rana
hi all, I have recently purchased a vr ss with a leaking master cylinder, I have a vs one here and I can see the there are slight differences in where the pipes come from that go to the abs module, will it still work ok if I swap them?
BlackVXGTS
Melbourne, SE
The master cylinders are different between the two models so I would say no, but others may have better information/knowledge.
immortality
Staff member
Sth Auck, NZ
VR MC uses a double flare fitting and on the VS MC they use the later style bubble flare I think(same as VT onwards). Both are 15/16" as far as I'm aware. So, no, not a direct swap unfortunately.
tim_pato
Tamworth
ok so can I swap the whole kit and caboodle?
tim_pato
Tamworth
would the vs abs module and computer work in a vr?
