Are VZ AND VY front atruts and strut tops interchangeable
Alex vl 383
41
Beachmere
Vy standard 6cyl
Hi.I just bought a VZ and need front struts and strut tops for a roadworthy. I have a VY .can I put the VY struts and toos on the VZ?
Tonner Matt
Darwin
VZ 1 Tonner LS1 M6
Yes you can swap the struts between VZ and VY.....The strut tops are an identical part between the VY and VZ also
You will have to use the Swaybar links from the VY when fitting VY struts to a VZ
Reason being is the swaybar links mount to the strut body in different ways between a VZ and VY
The VY uses a ball/pin style swaybar link
The VZ uses a ball/ball style swaybar link
Sandman
Challenge Accepted
HQ VC VZ
As Tonner Matt said will need to use VY Sway bar links.
Alex vl 383
41
Beachmere
Vy standard 6cyl
Thank you. The mechanic want $880. I have tge oarts and can swap them over now. Thanks again, saved me a load of money I don't have
