Ask the EX-Holden Technician
Discussion in 'The Pub' started by Doctor Bob, Jan 15, 2006.
Thread Status:
Not open for further replies.
  1. [p]wrr-247
    [p]wrr-247 Mr14ry
    near blacktown
    Vz Calais v8
    hey my vs keeps stalling wen i dont use the accelarator or stop at lights just started hepening today dont no wat it could be can u help me plz
  2. Slippy_Trippy
    Slippy_Trippy Unicorn Shepard
    Melbourne, VIC
    1999 VT II Commodore Acclaim
    What would be the best option to replace/reupholster beige seats in a VT with electric drivers and both with SRS. Upholsterers won't touch it cause of the bags and finding seats that color with those features is difficult to say the least.
  3. viewwest
    viewwest New Member
    vx berlina
    VX Berlina Air Bag Module
    Hi there
    I have a VX Berina (Series 1 - 2001) and have been told by my local garage that I need a replacement airbag module. The price to fix it was around the $400 mark but he suggested that I source the module from the wreckers.
    I was wondering how hard is it to remove the module so I can take it with me to the wreckers in order to get the right one etc.
    Much appreciated
    Peter
  4. teebo
    teebo New Member
    vr 2 v6 stock shita
    vr stalling at ac cut out.
    G'Day,
    First of all, good of you to lend your knowledge!
    My VR V6 is stalling after the a/c cuts out. The revs aren't staying at normal rpm, dipping and then stalling and then backfiring back through induction. Happens when changing from reverse to neutral to drive as well. I had a code 13 (Oxy sensor) changed that and cleaned throttle body and elbow adapter thoroughly. Still stalling. I'm thinking IAC, throttle position sensor unit is faulty or is it the fuel pressure reg, I found fuel in the vacum hose.
    (couple hours after first posting) - Ok, I've pulled out the fuel regulator and will be replacing. Whilst doing this I couldn't get a good enough grip on the regulator so I pulled off the fuel rail and injectors, and found 1 nozzle missing on one of the injectors (plastic nozzle tip with oring). Should I be getting it out or will it burn up?
    Please shed some light, Thanks!
    Dan.
  5. Doctor Bob
    Doctor Bob Grandpa
    Retired
    RG. Colorado & Caravan
    could be a problem with the swirl pot/return line system
  6. Doctor Bob
    Doctor Bob Grandpa
    Retired
    may have a vacuum leak or a sticky IAC
  7. Doctor Bob
    Doctor Bob Grandpa
    Retired
    Vt will do this sometimes if the BCM has had a minor brain fade, the security link from the PCM is lost, a dealer with a tech2 can relink it.
    Rob
  8. Doctor Bob
    Doctor Bob Grandpa
    Retired
    take it to a trimmer with a clue, working on these seats is safe when done correctly.
    if yu can buy the trims new ill fit them for you.
    Rob
  9. Doctor Bob
    Doctor Bob Grandpa
    Retired
    i wouldnt be using one from the wreckers... its a serious safety issue
  10. Doctor Bob
    Doctor Bob Grandpa
    Retired
    the reg should be most of your problem, the plastic bit shoud be fine it wont cause any damage.
    Rob
  11. teebo
    teebo New Member
    vr 2 v6 stock shita
    Doctor Bob's a champion.
    Thanks a million Rob!
    Really appreciate your reply mate.
    Thanks,
    Dan.
  12. Fekason
    Fekason Fekason
    Penrith NSW
    VE Cluster Swap
    Hi Rob,
    Any update on your ability to program a VE MY09 three window cluster yet? I am still looking to swap my SV6 cluster.
    Thanks & regards,
    Norm
  13. Doctor Bob
    Doctor Bob Grandpa
    Retired
    not as yet , the aftermarket software is proving difficult, a dealer can do it , they just need to have the knowledge on how to use the tools they have
    Rob
  14. [p]wrr-247
    [p]wrr-247 Mr14ry
    near blacktown
    Vz Calais v8
    hey thanx heaps for that
    if i do have a vacum leak is it fixabble or time for a new motor ??
    only bought the car like 5 months ago from a caryard an after i left the place started avin problems with it nonstop anyway just 1 more thing wats a IAC
    cheers mate
  15. jasonbw
    jasonbw New Member
    VX Berlina, VS Exec
    Dead right, and theres probably countless lurkers who've taken your great advice to save them $$$, I know I'm one... Thanks Dr Bob for your time and effort!
  16. gareth89
    gareth89 New Member
    Whyalla SA 5608
    A VR V6 bout to sell Yamaha Scorpio
    i own a vr vr commodore and the petrol gauge dosent work unless you hit the dash on top and it pisses me off.
    it has done it for 6-7 months and i am pretty certin every think works in that area
    is it the dash? or another faulty part? and how can i fix it???
    thanks heaps
  17. SuperSixty6
    SuperSixty6 Alto Rullo
    Brisbane.
    Landcruiser TD
    Hi Rob,
    Gerry recommended me ask my question in this thread, Hoping you can help me out.
    I have Vy that I am looking to convert to a manual. I have a Vt here that was involved in a crash, However it is a manual and all the running gear is fine.
    I am getting a lot of different mixed information on what I will need. Can you get me a list of what parts will be required to do this? I assume I need a Vy manual computer as I cant use the one out of the Vt? What wiring will I need? And will I need to use the Vt BCM?
    Thanks for any help, Please feel free to PM.
    Cheers,
    Ben/Super6
  18. nemesis_adrasteia
    nemesis_adrasteia better to reign in hell
    longford, victoria
    VR commodore HSV(without all the gay ****)
    hey mate, i was wondering if you could tell me if theres a way to reset the backlash in an IRS diff for a VR commodore v6, its fairly clunky at the moment. i have been told its screw adjust able not shims.
    cheers
    michael
  19. glen3.8
    glen3.8 glen
    nsw, riverina
    vs 3.8L t5
    Bob i need you!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    hi bob. iv been told you would be able to help me with this problem. i have a v6 ecotech and t5 gearbox out of a vs commodore sedan sitting in my lx torana. all is sweet and im happy with it but this thig has fought me all the way. and now im having trouble with the body moduel. i need to some how by pass it to trick the computer into thinking its the right key starting the car. the origional body modual was only the basic style with the 3pin plug not the 5 pin plug. some one said it was a matter of changing the memcal. how do i disable this bcm signal? you help will be very much appreciated.
    thank you so much mate. take care. glen
  20. Big 'VN' Kev
    Big 'VN' Kev Do a Skid ?
    VN Executive
    VN S1 Executive
    Is it possible to change, my instrument gauge, in my VN, to the V8 VN gauge with an RPM meter ?
    and if so, how much work is involved if i have to put in another plug ?
Thread Status:
