Ask the EX-Holden Technician
Discussion in 'The Pub' started by Doctor Bob, Jan 15, 2006.
Thread Status:
Not open for further replies.
  1. vr5speed
    vr5speed New Member
    brisbane
    vr s1 5 speed
    how do i fix my (vss) as code 24 comes up what is vss?
    thanks
  2. Thornado
    Thornado New Member
    VE Omega
    VE Steering Wheel Airbag removal
    Hey, this isn't a silly question, anyone know how to remove the airbag on the VE steering wheel, I've got a leather one to replace the plastic one, there's no bolts on the back of the wheel like the VT-VZ's?
  3. Doctor Bob
    Doctor Bob Grandpa
    Retired
    RG. Colorado & Caravan
    yes you can use the single pump, you will need to mod the pickup to sit in the fuel when you remove the internal pump
  4. Doctor Bob
    Doctor Bob Grandpa
    Retired
    it sounds like the AFM isnt reading correctly, just because you have tried another doesnt mean its not at fault, you need to check the wiring to make sure the signal is getting to the ECU.
  5. Doctor Bob
    Doctor Bob Grandpa
    Retired
    you need to replace the rack, not sure of the cost try a steering repair specialist/
  6. Doctor Bob
    Doctor Bob Grandpa
    Retired
    not sure... try it
  7. Doctor Bob
    Doctor Bob Grandpa
    Retired
    VSS = Vehicle Speed Sensor
    you need to get it working & the code will clear
  8. Doctor Bob
    Doctor Bob Grandpa
    Retired
    theres a special tool to get them off, its like a small tyre lever & goes in the back to pop it off, similar to VY VZ
  9. Nevyn
    Nevyn Member
    Latrobe Valley
    VN Sedan
    the holes don't quiet line up, but thats something that can be fixed.....the main concern I have is the pressure regulator and the rail looks a lot thinner on the S2 than the S1.
  10. Doctor Bob
    Doctor Bob Grandpa
    Retired
    why change it?
    for the pain making it fit etc theres no advantage?
  11. Nevyn
    Nevyn Member
    Latrobe Valley
    VN Sedan
    Why change anything on a car? And the only advantage I'm loking for is the fact I can polish the rail, which should look good against the manifold painted black., but like I said, I'm concerned about the 2 different regulators and thickness of the rail piping. If the fuel pressure will be the same and the thinner rail has no adverse affect on the performance or economy of the engine then the little pain to fit it will be nil, its just a new hole that needs to be drilled.
    But thanks for the replies thou :thumbsup:
  12. vr5speed
    vr5speed New Member
    brisbane
    vr s1 5 speed
    where do i find it?
  13. HER VN
    HER VN Tash
    Gisborne, New Zealand
    1989 VN Executive 3.8L
    Hey, should the pump that inflates the suspension make a really loud noise?
    I have a friend who rides around in a 1998 HSV Senator. He has had the suspension air pump changed like four times with the dealer he bought the car from, because each time he turns the car off it makes this really loud noise and I mean loud! Every time the car comes back from being 'fixed' by this dealer, the pump makes this really loud humming sound - would they be using second hand parts?
    Ordered, to buy a new one and fit it, my friend picks up the car yesterday, and when he gets home turns off the car, gets out and locks it, walks to the garage door and you know what, the noise is worse than it has ever been before!
    Should it be doing this every time the car is turned off whether long journey or short, and why is it so damn noisy lol
    We're confused about this one.
    Thanks
  14. Doctor Bob
    Doctor Bob Grandpa
    Retired
    cool was just curious, thats all
  15. Doctor Bob
    Doctor Bob Grandpa
    Retired
    its on the rear extension housing on the transmission where the speedo cable used to go
  16. Doctor Bob
    Doctor Bob Grandpa
    Retired
    its a small compressor it will make noise when its working, having said that it shouldnt be really loud though
    it may be mounted poorly?
    its really hard to say without hearing it.
    Rob
  17. Nevyn
    Nevyn Member
    Latrobe Valley
    VN Sedan
    no worries Rob....I'll let you know how it works out.
  18. 93vr6
    93vr6 New Member
    VR Executive
    Dr Bob,
    Where is the intake air temperature sensor on a Vr 6 cylinder?
    Cheers,
    Brad
  19. Keesh
    Keesh GM Parts tech. support
    HSV WL GRANGE LS2 , VQ 5L Caprice
    that car with the pump wouldnt be at my dealership would it? i remember a car coming in and it was loud as ***! i no the sound you mean
  20. spud42
    spud42 New Member
    VX II Berlina
    ok for the last week the delay before it starts to crank has been only 5 to 10 seconds so i couldnt tell but this morning it was taking forever... so i checked and the red led is not flashing while i have the key in the starting position. it finally started after 4 or 5 attempts each holding the key fully clockwise for 30 to 40 seconds or more. but again after it starts to crank it starts straight away. it just doesnt want to crank! and every time after it starts instantly... any idea? this is driving me nuts....
Thread Status:
