Ask the EX-Holden Technician
Discussion in 'The Pub' started by Doctor Bob, Jan 15, 2006.
Thread Status:
Not open for further replies.
  1. oedi
    oedi New Member
    VS Executive Wagon 1996
    gday doctor bob!
    Im my commodore vs 96 wagon the break lights are allways on when i switch on the lights,with switched off lights the break lights work like they should.I think its just wired up wrong,but could it be an indication for something else wrong?
    All fixed allready,it was the bulb and one cable installed wrong.
  2. vxchev
    vxchev Member
    S/E Melbourne
    VX2 CALAIS V8
    Hello Dr Bob,
    Is it possible to swap out a vx series one cruise control stork to a vx series two stork without any mod's or changing BCM.
    Thanks in advance
    Les
  3. Dipz1984
    Dipz1984 New Member
    vy executive
    Missing on Petrol
    Hey rob i have a 2003 vy v6 excitive commy its gotdual ful LPG and Petrol i use unleaded 95 in it all the time its started to miss when i use it on petrol. it runs fine on LPG but it started using heaps of LPG i had it servied and tuned abt a month ago as it was missing on both LPG and Petrol and now its missing on petrol and LPG simz to be running fine atm any ideas what could be wrong with it ?
    thanks
  4. luke355
    luke355 New Member
    vy ss
    need help
    Hi Dr Bob,
    Hoping you can help me i need to remove my alternator from my VySS series 2 and i was wondering if i need to remove the radiator and fans or is possible to reach without going to all that trouble?
    Thanks Luke.
  5. Johnsy
    Johnsy ★★★★★
    C/Town
    VF SS Wagon & VF SV6 Ute
    Hi Bob,
    Got the sat nav installed and they put the glovebox light in also without me asking... it must be part of the install so you can see the player at night prehaps ?
  6. Dipz1984
    Dipz1984 New Member
    vy executive
    HI Bob i have a 2003 vy v6 excitive commy its gotdual ful LPG and Petrol i use unleaded 95 in it all the time its started to miss when i use it on petrol. it runs fine on LPG but it started using heaps of LPG i had it servied and tuned abt a month ago as it was missing on both LPG and Petrol and now its missing on petrol and LPG simz to be running fine atm any ideas what could be wrong with it ?
    thanks
  7. ozdrummer
    ozdrummer New Member
    Vt wagz
    climate control
    OK i have an exec VT and was wondering if i could convert to climate control.
    I know i need heater box, temp sensors and all that but can i keep my standard BCM or would i need to change it.
    If it is possible to do the above. is there anyway of running a VZ climate control unit with either VZ or VT parts (temp sensors, heater box etc)
    cheers for the help.
  8. cavantrev
    cavantrev New Member
    92 calais vp
    hey now have a 92 calais v6 tickey rattle sound from engine when a/c comes on the belt tensioner hops up and down does move much when its off it has new water pump belt tenisoner and the haromic balancer pulley looks new when i take the belt off and run the engine it runs quiet there a click in alt when you spin by hand and a few clicks in a/c pulley when you spin by hand . is this a bearings issue and would it be easy fixed what about using the a/c when the belt tenisoner is jumping like that is it risky .. any answers would be great thanks
  9. vn6cal
    vn6cal New Member
    vn v6 Calais
    I have a vn6 calais and the LCD's on my cluster have stopped working, the gages did but I re-soldered the voltage regulator back on and got them working again, I have searched everywhere for answers but nothing has helped. Can this be fixed or will I have to get a replacement cluster, Also my mate says I can put either a L1 or L2 cluster in til I get a L3, is this true.
    Thanks
  10. Marcus2356
    Marcus2356 New Member
    VY2 Acclaim 3.8
    I have a VY V6 acclaim on LPG (dual fuel)-- I holed the sump on a stupid council medium strip at night
    Sumps replaced - but when i travel at around 100kph
    the check light comes on -- i go to petrol and light goes off - never goes on below 80kph around town on gas
    Gas place scanned (that cost me with a tune and new mixer too and a set of Stainless plug leads)- didnt fix it but came on less often) scan on return showed Oxy sensor and TPS issue
    I changed both Oxy sensors myself as got em Trade and check light came on once and not again for over 100km - havnt tested or scanned again so could it still be the TPS or maybe a damaged catalytic convertor from the sump knock? Since checked cats and they are fine (are any fine particles that tap out of inlet side unburnt petrol particles or bits of the cat - exhaust shop said former)
    Do you think there may be a MEMCAL issue? The computer isnt being fooled that it thinks its still in petrol?
  11. garysholden
    garysholden New Member
    VK Calais
    Blew the manual gearbox on my Vk. Had a spare auto box which i put in.
    Drove fine for a day. Now its lost all drive/power. Oil looks good, no leaks, no obvious faults etc??
    Not an auto fan and am at a lose. Any ideas??
    Gary
  12. gasnier3
    gasnier3 New Member
    VR Commodore Series 2
    Hey DOC, I have a 95 VR and it wont run properly, it idles than stalls, when i rev it it dies straight away unless i release the throttle. I haveremoved the fuel tank and replaced the pump etc. Pump works fine but when in tank it is loud and sounds like its working to hard and nothing is coming out of the tank? When i blow down the return line fuel comes out fine though stops when air stops. Any way to solve this? The lines are all clear and the filter is new. 0419683208 any help would be greatly appreciated
  13. Zeussy
    Zeussy SSM11K
    Central Coast
    Gen-F Clubsport, Rodeo 2.8 TD 4x4
    heyy not sure if its been brought up already, but do you know how to replace a steering lock on a vt commy??
  14. roxy84
    roxy84 New Member
    98 vt commodore
    possible fuel probs?
    hi i have a major prob with my vt, i can start it and idles fine but as soon as i touch the accelerater it shutters really bad and dies, when it first died going up a hill it was on very low fuel, have put more fuel in still no change any ideas?
  15. guyman
    guyman New Member
    03 VY_S
    hi..
    just got an aftermarket h\u installed in my vy and the antenna doesnt retract when a cd is playing and stays up constantly. Just wondering if there is antenna fuse somewhere that i could just pull out. I rearely even use the radio.
    cheers
  16. PSYKO PHOENIX
    PSYKO PHOENIX AHHHH brain fart
    Auckland, NZ
    1995 VS Commodore v6 ecotec
    hi mate i stumbled onto this thread by accident last week, ive beeen having some trouble with an auxiliary trans cooler mounted to my 95 vs commodore exec,
    here is the thread ive been posting in
    http://forums.justcommodores.com.au...88982-replacing-radiator-need-help-quick.html
    im hoping you can shed some light on the subject
    what way are the hoses supposed to run through the rdiator/trans cooler, what way is the fluid supposed to run through the trans cooler
    etc etc etc
    hopfully you will be able to understand what i mean and tell me how it should look/run
    you get my drift
    love you work
    cheers mate
  17. ffej
    ffej New Member
    vys
    how do I remove cd from player with cd error message
  18. Doctor Bob
    Doctor Bob Grandpa
    Retired
    RG. Colorado & Caravan
    not without seeing it, the bbq fuel fitters should be able to sort it out.
    its normally the system they have fitted that screws something up.lol
    Rob
  19. Doctor Bob
    Doctor Bob Grandpa
    Retired
    yes you may need to change the connector to suit the stalk
  20. Doctor Bob
    Doctor Bob Grandpa
    Retired
    you should be able to get it out from underneath
Thread Status:
