Ask the EX-Holden Technician
Discussion in 'The Pub' started by Doctor Bob, Jan 15, 2006.
Thread Status:
Not open for further replies.
  1. Sawnoff
    Sawnoff New Member
    VE Calais
    Hi,
    I've just acquired an 07 Holden Calais VE Sedan (V6)-automatic transmission. Prior to that I had a VS Exec Sedan (V6)-automatic. So this a very, very different vehicle to what I am used to. Am not used to a vehicle that so computerised. Am also sad to admit that my vehicle mechanical knowledge fits on a postage stamp. Anyway just wondering if you, or anyone else, can advise me what's normal and what's not in terms of the tachometer RPM's in various driving conditions ie on the open road, driving uphill, driving downhill.
    :confused:
  2. newbyone
    newbyone New Member
    vs statesman
    can anyone tell me what the best gearbox and diff ratio for a vs v8 statseman 5L
  3. hwy747
    hwy747 New Member
    South-west Sydney NSW
    VXII Berlina 5.7L / VW Golf GTi
    VX Calais electric seats into VX Berlina
    Hi Dr Bob
    I have recently installed a set of VX Calais leathers into a VX Berlina. Drivers seat electrics work perfectly with full movement, but the passenger side does not move at all. I know the Berlina seats are not electric, so I am going to have to run the cables, however, is there a way I can move an electric seat manually (forward and back only) as I need to screw the 2 front bolts in to keep it anchored?
    Thanks
    Iain
    :bang:
  4. andyman
    andyman The Only 6sp VZ Wagon
    Orange, NSW
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    if you want it manually try changing the seat base
  5. andyman
    Orange, NSW
    you can fit it all in if you swap the k frame, electrical gear, front suspension etc, the only major problem you would probably run into is compliance side of things, ie fitting an older model engine into a slightly new car
  6. [QLIMAX]
    [QLIMAX] New Member
    VZ Maloo
    hi today when i go around some corners at slow speeds the hand brake light in my vz pops up and stays on for up to a minute or two? it doesnt feel like its on though but its annoying ive checked the cables to the back and theyre ok?
  7. andyman
    Orange, NSW
    the brake light indication is used as a brake fail light so to speak, as well as handbrake, check and see if the brake fluid level is at the max mark, the level float inside the resivour isnt stuck down low in the resivour,
    if the level is down, check to see if there is a fluid leak somewhere, thats a start anyway
  8. Doorstopper
    Doorstopper New Member
    VZ Equipe
    ABS Fault in VZ equipe
    When starting my car I get an ABS fault on the dash with seven chimes. The dealer said it could be one of about twenty sensors and doesn't seem interested and has only reset it but hasn't fixed the problem. Has anyone heard of this one before.
  9. Doctor Bob
    Doctor Bob Grandpa
    Retired
    RG. Colorado & Caravan
    check the battery voltage when cranking, it will probably be a bit low causing the ABS error
  10. Doctor Bob
    Doctor Bob Grandpa
    Retired
    if you get under the seat you should be able to see the motor, sepending on the exact model seat base (there are several) you can manually turn the driveshaft on some, if not just connect power & ground to the appropriate pins at the seat connector & move the seat
    Rob
  11. neblol
    neblol This ain't rocket surgery
    VR Executive 3.8
    This is more of a general question about the Central Locking Utility in my recently purchased VR Executive Commodore, Now when I press the button on the keys I can hear the click but it doesnt unlock the doors. I have tried both keys separately so I know its not a battery issue. Im just wondering what this is and how it can be fixed (perhaps without taking it to a car workshop and getting shafted?)
    I hope that explained it, if you need to know more just ask, Thanks in advance for taking the time to respond to this.
  12. Fekason
    Fekason Fekason
    Penrith NSW
    VE Cluster Changes
    Hi Dr Bob,
    Any updates on changing to up spec VE clusters yet?
    Thanks & regards.
  13. Doorstopper
    VZ Equipe
    Thanks Dr Bob
    Will do, Holden have also got back to me and are going to monitor this with the dealers service dept. Will keep you posted.
    Regards Doorstopper
  14. [QLIMAX]
    [QLIMAX] New Member
    VZ Maloo
    thank you, the resevoir was very low. It has been happening since I painted my calipers, I topped it up for now but its getting checked this w/e
  15. Perth_5.0_Man
    Perth_5.0_Man Please Pimp my ride
    Vs Berlina 5ltr/Vp exe 5ltr
    hey doc i was just wondering wat the flo cal on my trip computer is or why its adjustable or should i just leave it thanks btw its a vs s2 belina 5l
  16. whatsdown
    whatsdown New Member
    vs acclaim
    is there any way to change the gear noob on a 1996 vs auto
  17. Doctor Bob
    Doctor Bob Grandpa
    Retired
    its adjustable to allow for differences in cars, there is a procedure to cal it exactly, its been posted on here somewhere . do a search for it
    its up to you but remember to write down the original settings if you bugger it up
    Rob
  18. Doctor Bob
    Doctor Bob Grandpa
    Retired
    yes, take the old one off & put on a new one
  19. aceventura
    aceventura Doesn't drive like this
    SEQ
    Mazda 6
    Hi Bob,
    Trying to work out what the fuel pressure at idle should be for a VS - mine is 240 kPa.
    Gregory's says it should be ~280
    Hayne's says it should be 240-260 (in which case mine is ok)
    Which is correct?
  20. pjdm1980
    pjdm1980 Shut up Jr I'm thinkin!
    Geelong, Victoria
    E1 GTS BUILD NO# 007, GQ Patrol.
    bad earths on O2 sensors
    Do you hear much about bad earths on O2 sensors?
    The guys at LPGAS1 said both my earths where no good and the guys and it gave my car flat spots.
    Thanks Pat.
Thread Status:
