I have a originally 6 cylinder car, Now it has a V8, My In Dash tacho reads way above actual rpm, is there something I can add to the Coil wire to covert it to V8? as Tacho does not have any switches on the back....??
Cheers, Chrisso.
Thanks for this thread Tom!
Quick question. Torana LH/LX SLR instrument cluster.
I've had mine modified, i.e the regulator removed & replaced with a diode setup. What do you charge for this service?
Are the stock regulators the same between the standard cluster & the SLR cluster?
Cheers, Col.
What model car is it?. Most tachos have to be converted internally or with a tech2.
