ATTN all VR/VS berlina/calais owners
SWE11L
VS Berlina/ KJ Verada/ 88 Trans Am
has anyone had a problem with their climate control where it doesnt come on when you press the buttons, but will randomly turn on after the cars been running for a little while? its driving me insane!!!!
scorpio
VR CALAIS 5L HSV ENHANCED
i havent, but mine seems to restet itself after i turn the ignition on and off
SWE11L
yeah mine does that too plus it doesnt light up... i just recieved a replacement that i bought off ebay which was from a vn and it doesnt operate properly in the vs.... got to resell it now.... anyone else out there thats experienced it an had t fixed let me know!!!
stocky
37
what do you mean it doesnt turn on? the AC system, or the control module itself?
SWE11L
the a/c an heater is completly inoperative, as if it has no power going to it... its wierd when it happens, if i had it on the last time i turned the car off and it doesnt come on when i go to turn it on the next time i drive, it will randomly come on as im driving, if it wasnt on the las time i drove i'll know when to turn it on cause after a while i here a sound like the vents are opening or something, then its ready to use.... very strange and very f 'n annoying.....
BowTieGQ
4.8 ;)
Easy fix. Open the relay box cover behind RH headlight. Now I forget which one, but I think the relay second from left, which might say something like A/C on the cover, is powered by the relay about 2 to the left. Does that make sense? It's the one that powers it that plays up. I payed a Holden dealer lots of money to not work that one out. Found it myself. Actually I just remembered, it also has something to do with the thermo fans. When they came on, so did the climate control, so the relay may have been that one. To fix, take out the horn relay and swap it with the suss one. I no longer have a VS to open bonnet to check sorry. Hope this helps.
SWE11L
BowTieGQ, if you were a chick i'd ask you to marry me!! If that relay swap did for your VS what it has just done for mine, you know how i feel.... not only is the a/c coming on at command, it has corrected rough idleing and over revving of gears going from second to third and manual changing of gears with the stick is so much smoother and doesnt jerk forward or back when choosing reverse or drive......its like its just had a full service... dont know if you had results like these but i'm happy as motherf@*ker.....you are a genius!
sixshooter
2x VS
Yeah it was the first thing I fixed when I got my car... it turned out to be the vacuum solenoid switches under the radio. It's a little square box with about 5 holes the size of 5 cent pieces... new they're about $130 @ wreckers about $30.
If your vents dont all work when changing through them manually. Then that could be your problem. On mine I couldn't get the centre vent to work and when in auto it always wanted to send air to the floor.
Hope that helps !
Agh never mind...I just read your last post...good to see it's all fixed !!!
Immortality
Staff member
Sth Auck, NZ
HSV VS Senator, VT s2 Exec, VX Calais II L67
good to see a man happy with his ride. best responce i've seen yet to a solution to someones problem. excelllent:thumbsup:
