johnno010684
- Sep 18, 2008
- 552
- 1
- 0
- Age
- 39
- Location
- Auburn
- VX Clubsport M6, Subaru Brumby-daily, TM Magna
if i install ten, will my car run 10's? haha
i highly doubt it is the sound system unless as most people have said your foot gets heavier when listening to music that gets you pumped up, but also the large power being drawn could be a problem... possibly.
An alternator is just a coil of wire and magnet basically, As you increase the power being drawn, the alternator becomes more difficult to turn, ( F=NxBxIxL ) and therefore the computer needs to put in more fuel to turn the alternator at the same rate. This means you don't need to be putting you foot down for it to be using more fuel.
Maybe invest in a capacitor? like i said i'm not 100% sure but large current or power being drawn can result in larger fuel usage.
sorry if i'm wrong but just a suggestion/thought
My old 4cyl would bog down when there was massive current draw. I was drawing over 200A and the engine would bog down and then the car's computer or whatever would boost the revs back up. This was only noticeable at idle.I love misinformation. Please enlighten me how the alternator can cause more strain on the belts when it's spinning at a fixed rpm in accordance with the motor. I'm pretty sure if the tension changed even just a little bit it would throw everything out of whack.
