Autel Maxidiag US703
TonyJZX
East Coast
Commodore M6
who's got one and who's been finding it useful?
the big OBD thread seems to be gone
i'm just playing around with the live data stuff so far
DLFHUB666
GIT 'EERRR DONE!!!
Nhulunbuy NT
VX SS, PX Ford Ranger XLS Dual cab
Yep have 1 very helpful so far i have used it in my vx an on the misses jg cruz as well.
DLFHUB666
GIT 'EERRR DONE!!!
Nhulunbuy NT
This will help you abit Tony:
B1 Left Side of engine drivers side
B2 Right Side of engine Passengers side
S1 Left Side of engine drivers side before catalytic converter
S2 Right Side of engine drivers side after catalytic converter
DTC_CNT 0 (Diagnostic Trouble Code Count)
FUELSYS1 OL (Fueling Mode (OL Open Loop CL Closed Loop)
FUELSYS2 OL (Fueling Mode (OL Open Loop CL Closed Loop)
LOAD_PCT(%) 3.5 (not sure? Peak Torque Curve)
ECT(�C) 38 (Engine Coolant Temperature)
SHRTFT1(%) 0.0 (Short Term Fuel Trim Left Bank)
LONGFT1(%) 4.7 (Long Term Fuel Trim Left Bank)
SHRTFT2(%) 0.0 (Short Term Fuel Trim Right Bank)
LONGFT2(%) 4.7 (Long Term Fuel Trim Right Bank)
MAP(kPa) 65 (Manifold Air Pressure Kpa)
RPM(rpm) 145 (yeh)
VSS(km/h) 0 (Vehicle Speed Sensor)
SPARKADV(�) 11.0 (Spark Advance)
IAT(�C) 25 (Intake Air Temperature)
MAF(g/s) 2.14(Manafold Air Flow Grams/Sec)
TP(%) 0.0 (Throttle Position)
AIR_STAT OFF (not sure)
O2SLOC B1S1---B2S1--- (not sure)
O2B1S1(V) 0.555 (o2 sensor voltage Left Bank)
SHRTFTB1S1(%) 0.0 (02 sensor short term fuel trim Left Bank)
O2B1S2(V) 0.445 (02 sensor voltage Left Bank, o2 after cat)
SHRTFTB1S2(%) 99.2 (O2 sensor short term fuel Trim Left Bank, o2 after cat)
O2B2S1(V) 0.605 (o2 sensor voltage Right Bank)
SHRTFTB2S1(%) 0.0 (O2 sensor short term fuel Trim right Bank)
O2B2S2(V) 0.445 (o2 sensor voltage Right Bank, o2 after cat)
SHRTFTB2S2(%) 99.2 (O2 sensor short term fuel Trim right Bank, o2 after cat)
That is the **** right there thanks soop an the1
vh5000i
Wollongong
VH SLE 5.0i
Has anyone tried the US703 to reset the SRS codes on the LS1 equipped commodores i.e. VTII onwards. I have a VXII LS1 berlina and was considering purchasing this scanner for this car.
Torquative
Sports Economy
VE SV6 3.6L SIDI 6sp
lol ironically I have a thread in the VZ section about using it on VZ (I only found this thread when it suggested it at the bottom of the forum)
I can confirm for VZ it doesnt talk to the SRS module whatsoever, despite the seller telling us it would then changing his story, but more intense reasearch on my behalf and I got confused, so Ive left it there.
It definately has access to SRS in other cars when you flick through the manual options (like 2005 Pontiac Y series) so I'm interested to know for curiosity
DLFHUB666
GIT 'EERRR DONE!!!
Nhulunbuy NT
Just thought i would add to this thread. I just used my us703 on a Triumph thunderbird storm 2013 model to check a code we then fixed the problem and erased the code aswell. who would have known. :)
DLFHUB666
GIT 'EERRR DONE!!!
Nhulunbuy NT
This works with my 2014 px xls Ford Ranger. reads/delete codes and all lives readings. :)
