Auto Breather Hose
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by benno9911, Jun 6, 2010.
  1. benno9911
    benno9911 Donating Member
    Warrnambool
    03 VY S2 Exec
    Where dose the hose go cause i have looked and i carnt find a place to plug it in to
  2. bandit10
    bandit10 Member
    VE SS
    it doesnt go anywhere, just sits on top of the auto.
  3. benno9911
    Warrnambool
    03 VY S2 Exec
    dang i was hoping it was the casue of one of my problems got the new motor in and running but its reaving really high before it changes gear unless i back it off its full of oil
  4. bandit10
    bandit10 Member
    VE SS
    didnt you use your old trans?
  5. benno9911
    Warrnambool
    03 VY S2 Exec
    yer i am using the old one
  6. bandit10
    bandit10 Member
    VE SS
    strange.. if your using your old auto would of thought it would be the same as before
  7. benno9911
    Warrnambool
    03 VY S2 Exec
    how about the vacuum hose where dose that go
    yer me to the only thing we did was change the oil and filter and gave the outside a clean oh well looks like it will be going to to the mech asap
  8. bandit10
    bandit10 Member
    VE SS
    have you checked the oil level with it running and in N ? could be a little low maybe?? when u changed the filter did you make sure you pushed it in to the valve body as far as it would go?
  9. benno9911
    Warrnambool
    03 VY S2 Exec
    yer i did my step dad just saying give it time give it time it just got to get used of the new oil casue it been running on burnt black oil
  10. bandit10
    bandit10 Member
    VE SS
    why was the oil black? have you been towing with it? black oil is burnt from excessive heat or slipping trans
  11. bandit10
    bandit10 Member
    VE SS
    hopefully it will come good :) my car had black oil in the trans when i got it, used to hold gears way to long, 6 months later and 2 services its good as new.
  12. benno9911
    Warrnambool
    03 VY S2 Exec
    nar i did not tow with it but i did have a overheating problem with a little while ago and i planed to have it serviced but i never got around to cause i kinder blew the motor and things keeped braking on it
  13. wraith
    Demonicaland
    VX V6 Berlina. 2003 VW Passat
    Was it doing it before the engine swap? Is it every gear that's revving out? Check the oil level. If you put too much oil in it, it can cause too much pressure on the band's as well.
  14. benno9911
    Warrnambool
    03 VY S2 Exec
    i am going to take it for a longer drive tonight so i will see if its doing it agian
  15. moff_man
    moff_man operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    did you reuse your old tps/ throttle body? maybe the new tps/throttle body is buggerd, that would make it hold gears and such.
    also trans should be checked in park, not netural.
  16. benno9911
    Warrnambool
    03 VY S2 Exec
    no i used the same inlet manifold cause 2 weeks before the motor went i had it cleaned and i always check it in park
  17. benno9911
    Warrnambool
    03 VY S2 Exec
    took it for a nice drive down the highway and for some reason its changing in to every gears nicely now
