Snicko1
- Sep 16, 2014
- 84
- 0
- 6
- Age
- 40
- Location
- Australia
- VF Calais Wagon
Hi Guys,
performed an upgrade over the weekend, i was getting sick of replacing batteries in my garage door opener so I ordered a homelink Auto dimming mirror from the US.
I use to have auto dimming mirror in my previous car but the calais lacked it. Easy mod that took about 30 Mins.
Cost under $100 dollars delivered
Mirror can be bought from here with delivery and cover it was around $83 for me, but i notice postage has since gone up making it around $120
NEW Gentex Homelink Rear View Mirror W Auto Dimming AND Wire Cover | eBay
Wiring - I used a USB 10 Pin header as this fitted it, as finding the connector to match the mirror exactly was impossible, you only need 3 pins
USB 2 0 Port Expansion Bracket Plate ADD ON Header FOR Asus Gigabyte MSI Intel | eBay
Pins - I bought new pins but you could simply use the USB cable but i thought it was a bit thin
PC Pin Sockets to Suit PCB Pins - Pk.25 | PCB Pins & Sockets | Terminals & Headers | Interconnect | PRODUCTS | HP1260 | Jaycar Electronics
Cable - You only need 3 core, i used some 4 core Alarm cable, you can use the USB cable if your comfortable to. 4 Core 14/020 is best but you can do it with this one also and it will work fine. The 14/020 is easier to work with the crimp pins
4 Core Alarm Cable | Alarm | Figure 8 & Composite Cable | Wire, Cable & Accessories | PRODUCTS | WB1590 | Jaycar Electronics
Or
4-Core Pro Audio Speaker Cable | Speaker | Figure 8 & Composite Cable | Wire, Cable & Accessories | PRODUCTS | WB1762 | Jaycar Electronics
The process is pretty simple to wire up, wiring can be tapped into at the interior roof dome light.
There is a ground and a 12v accessory feed that powers up when a door is opened or the car is started
If people are interested ill throw some pics up detailing the pins and wiring.
All up great mod and works with both our BOL4 Steeline / Boss garage door openers. I have programmed both doors to 2 of the 3 available buttons. For the record my garage transmitter operates on 303Mhz.
Step 1 - Remove your existing mirror - Using a Torx T20 loosen off your existing mirror and slide upwards towards the top of the screen.
Step 2 - Get new mirror and mount on to the Wedge - Tighten using the Torx T20
Step 3 - Make a wiring loom using the below pin outs and 10 pin header
Step 4 - Using some wire strippers, strip back the wires below from the map light connectors about 3 or 4mm. Join the ACC & 12V to the 12V pin, solder it on, Then join GND to GND. Secure with solder and then wrap in PVC electrical
Step 5 - Remount your sunglass holder in place
Step 6 - Program the button by holding down Programmable button 1 & 3 for 20 Seconds. Get your remote transmitter and hold down the button to open your garage and at the same time hold the button on the mirror you want to program that transmitter to, it should flash when it has copied it. Repeat the process and then turn the mirror off. You should be all done now. Test the button works by opening your garage, When you press the button it will light up Red
Or
