stooge
- Apr 3, 2014
- 3,122
- 3,026
- 113
- Location
- wa
- Turbo Alpaca
this is a basic retrofit for the auto dimming mirror found in the upper spec zb commodores.
this is still on my bench but i will update this thread once installed but this is the pinout i have worked out.
this mod is simple as all you need is ignition switched power and to tap into the reverse lamp so the mirror does not dim when you select reverse.
*when i get some time to install this i will update this thread
