auto shifter
Discussion in 'VZ Holden Commodore (2004 - 2006)' started by gungazza, Oct 31, 2018.
  1. gungazza
    gungazza Well-Known Member
    west suburbs
    executive vt 5.0lt VZ CREWMAN
    just started to have a problem starting car in park just a click if i put it in nutral it will start is there a nutral sayfty switch on the trans that may have come loose
  2. gungazza
    west suburbs
    seems to have come good ??? would not start in park or nutral
  3. chris knight
    chris knight New Member
    australia
    ve sv6
    steering lock??
  4. gungazza
    west suburbs
    went ok for a week come saturday no start havent had a good look at it yet have to resurch it a bit
  5. gungazza
    west suburbs
    went out to day. and it started turned it off, no start where is the nutrul safety switch located
  6. chris knight
    australia
    ve sv6
    i wouldn't really know but would say around the shifter or gearbox? haha
  7. rambunctious
    rambunctious Well-Known Member
    Mooloolaba
    VZ Wagon
    I would be thinking more a column switch/rod related issue.
    Having said that, I was having the same dreaded single click so I charged the battery which at first seemed to help, but it has started doing it again.
    If your's is like mine where I have to remove the key and reinsert after each start attempt, then maybe, just maybe, it could be a barrel/key issue.
  8. gungazza
    west suburbs
    yes i looked at the rod adjustment, in the book but idont think its that, as i said, it started yesterday, after tuning it off would not start, will have to jack it up, and have a look ,hopefully loose plug lol is there a switch under the shifter
  9. 99notout
    99notout Active Member
    VZ Equip Wagon
    Here is the neutral start switch if you have the 4 speed 4L60E
  10. gungazza
    west suburbs
    thanks for the file thats what i needed
  11. gungazza
    west suburbs
    well turned out to be starter motor i just changed that seems to be all good now ff
