auto to manual reverse lights
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by lufkin, Oct 9, 2012.
  1. lufkin
    lufkin New Member
    SA - Victor Harbor
    WH Manual LS1 Statesman & VT V6 Calais
    Hi guys i just purchased a WH statesman that's been converted to a manual, but the reverse switch on gear box hasn't been wired in, there is still the old loom there for the auto box, just wondering if anyone had a wiring diagram for the auto plug, and is it possible to tap into that and hook it to the reverse switch, hope that made sense
    Thanks
  2. timt1205
    timt1205 New Member
    warrnambool
    vt bt1 5lt 5 speed
    Howd ya go with the reverse lights as i have the same problem just wondering if u could help out? Cheers
  3. A+d+a+m
    A+d+a+m New Member
    Perth, WA
    Vx Series II R8 Clubsport Build 295
    Currently in the process of converting to a t56, i found the Light Green and Brown\Blue wires found on the passenger side of the Auto loom turn the reverse lights on and off when connected to the Reverse socket found on the drivers side of the Manual Box, From what i know they aren't polarised so just plug it in.
    Hope this helps
  4. timt1205
    timt1205 New Member
    warrnambool
    vt bt1 5lt 5 speed
    No worries thanks ill give it a go cheers
