Auto to Manual speedo solution
muttley383
Donating Member
VR 383
Hi,
some may be interested in this device I have recently fitted to get the speedo working after a manual transmission conversion from an auto.
I used a product called speedohealerV4 on a VR commodore. I had to get the manufacturer to customise the unit to have a hall effect 3 wire input and a 2 wire magnetic output. This unit allows you to retain your auto PCM and still have the speedo working. Ie: set the unit for approx 950% and use the output of the device to feed the PCM as normal and in turn the PCM drives the speedo.
The unit is the size of a match box and has an adjustment range from -99.9% to 9999.9%.
The unit cost me 96.00 Euro delivered from Hungary but they do have Australian sales agents, although the custom units would not be stocked.
Info can be found at/www.healtech-electronics.com/
"No fixed address" Auckland, NZ
VS Calais Supercharged "Auuusiecouch"
Ok so I emailed them and received this reply;
"Cost is 84 EUR + 8 EUR shipping.
You can place an order on this page:
HealTech Electronics Ltd.
Select the "SH-V4-2W Kit"
and during the checkout, mention in the Notes:
"3 wire Hall effect input/2 wire magnetic output"
:boxing: YeeHaaa take that Auto ECU !!
:spot on: T5 into my VS with Auto ECU here I come!
:rofl2:
