What would I be looking at to change my auto to manual? Some people out there must of done it in their VR/VS?
VR motor is different to VS ecotec motor. I know the VS model has two different VSS (Vehicle Speed sensor) comparing auto to manual. The auto is an inductive pickup design and manual is a hall effect.
Lets see....because I already own an auto VS that is the colour I want and has some mods done to the engine so if possible I'd like to keep this one and not buy another one. I'm not an expert on these cars so thats why I'm asking Canman
good one. you try finding a manual vr!! anyway if the car is a vr model try a vn or vl manual but remember to get a custom loom or at least a tech book so you can rewire properly. cost all depends on how much work you do and how much you can pick up a gearbox for. best of luck
At the top of this page there is a SEARCH funcion. If that doesn't help go to google. THEN come here and ask.
i know someone that spent over $4000 converting their VS Calais (v8) to a manual. "Thought" about it myself, but when i found out how much she paid for it........ Didn't think it was worth it
hey i wouldnt even bother about it because even if you find a cheap box then u gotta pay someone to install it for u.... i got quoted $4200 for mine to get done so i thought i would just stick to the auto
A Full Conversion Kit on Ebay Hi, In case you are interested, there is a full conversion kit on Ebay. Search Ebay for 4571917541. Ends around 9:40 tonight (Friday). Currently at $340, but would be expected to go higher. It is obviously cheaper to buy a manual rather than convert. However, there are not many available. Where are you located? The kit above is an hour north of Sydney, and I have seen a manual VS in a local car yard in Penrith this week. I have had a number of manual Commodores, and driven numerous autos through work. Would never buy a slush box.
Like everyone else here says and many people have told me before. If you want a manual go buy a manual. Dont try converting the time money and hassle is not worth it. That or live with the auto.
You can get the conversion kit with everything needed for around $1600 (reco gearbox). Labour on putting it in can cost you a fair bit, but if u traded in your auto box that could reduce the costs.
as i just said in another thread, my mate has had this mod done, and i thought it was great. it only cost him 2200 bucks, and that was drive in, drive out. it depends on wether it's a series one or two, cos in series two they bought in a hydraulic clutch, so this may be more expensive to get fitted, not sure. just ring around a few wreckers, and such to find a good mechanic to do it.
this has been covered too much. please use the search button. then and only then ask about the conversion if your unsure. the cost is about $3000. if your after specifics then it may be best to talk to a trans place. admin/mod please close this topic.
if u like ur car, stick with the auto, and just put on a shiftkit for it.... not expensive at all, and will work much better then u tryin to convert to manual...
i got a kit for 1650 i can fit myself but im just after the different wirring i need to do if anyones got it or know what needs to be changed? and also does it need to be enginered?
ill tell u now, there is nothin as fun as a manual car and cos mine is one of the 2% made factory manual its even sweeter. sorry to rub it in unless u can do the conversion urself, ur lookin at spending a fair bit of cash, and also it can be hard to find good parts for the right price. to be honest, i cant really point u in either direction, cos i love driving manual but i wouldnt spend the money to convert.
Meh, I can't be bothered reading all of the replies in this thread, but as I'm in the process of doing this to my car, here goes: You need the manual gearbox out of a VP Series 2, or newer, 5 speed (You CAN get the VS one as well) You can't go any earlier then the VP Series 2, unless you change your crank, as they have different flex plate bolt holes. (5 on VN/VPS1, 8 on VP S2 onwards) The V8 box WON'T fit a V6, unless you get a V6 input shaft, although you can have a V6 Input shaft machined to fit a V8. (V8 runs a shorter input shaft) I bought a whole conversion kit for $950. All I need to do is get it all bolted in. Avg price for a whole conversion kit: $1500 - $2000... Not to bad, considering the price of a auto-manual car can make the car value jump by around $3000. I haven't yet sussed out the speed sensor part yet. Will be doing it later.
