auto transmission stops working
michaeljohn1234m
62
central coast
vu ute
VE Commodore sv6 5 speed auto
The auto transmission stops working when it gets hot. Engine still runs properly. After 3 kms from cold start car just goes into neutral when stopped at set of lights.
Has anyone heard of this problem as nothing is coming up on the dash.
Once it cools down it goes again, but only for about 3kms or until it gets hot
Asmodai78
VE Calais V Sportwagon
have you had it serviced lately? it sounds like its over filled
losh1971
North Tas
VE Series I SS Ute
Sounds like it needs a service.
commy vk
South Australia
commodore ve
May not be of any help but try changing F9 TCM fuse in engine bay black box.
_R_J_K_
Zenki S14
no, it hasn't been serviced
I'm wondering if the auto has a sensor that it might be that
You should try changing the oil at a minimum, maybe look at getting a trans cooler in conjunction.
Sensor issue will be a bandaid fix (if it works) without basic maintenance like fresh transmission oil, it failing when it's hot is a pretty good sign of transmission fluid that's far past the point of no return. The long term condition of the bands will rely on maintenance given the reliability of the 5 speed is apparently not that great.
gossie
Gold Coast.
VE International 3.6L
Auto transmissions like anything need servicing or repair. When was it last serviced?
michaeljohn1234m
62
central coast
vu ute
I talked to the local guy (central coast auto transmissions) he said the torque converter has broken up and is clocking the filter and stops the pump and when you turn it off the crap falls back into the sump and off you go again (it took three goes, to get it to his shop tonight. Just turn the car off, for one minute, then off you go) they will have a look tomorrow
