Automated Antenna extensions
Seanyy
"HULK"
Melbourne, VIC
VX II Acclaim
Hey guys,
On my VX when i turn my head unit on, my antenna also extends to full reach.
I know this is normal, thats not the problem.
I only ever use my AUX port, never the radio, and look like a spack driving round with my antenna up blasting out non-mainstream music.
Is there any way that I can stop the antenna from extending myself? Or is it an auto-elec's job?
acarmody
Donati..Whoa Green
VX Berlina
Just add a switch to the power wire.
Thorby
VF SS Black Edition Wagon
Hey guys,
Disconnect the plug behind the plastic shroud inside the guard. Problem solved Cheers
wayne92
VT II Olympic
yehh i had the same problem, i just removed the inner guard and then theres a plug that will have a red + white wire going into it, just unclip that plug and problem is solved
Seanyy
"HULK"
Melbourne, VIC
VX II Acclaim
Dont murder the newbie ;),
But where and what is the inner guard exactly? Never heard of it.
Trayner
Fresh prince of Pakky, Gangsta
Gangsta Hundy
Just splice into the wiring and add a on/off toggle switch , splice into the positive +
so when you dont want to to go up when you have the car on switch to off then when you want to turn it on etc
oska
vx custom 600RR
the white wire controls the up/down function +ve it goes up remove the +ve it goes down
hope it helps
Dayvo
Because i can
67
South East,Victoria
VE SV6 Series 2
THe inner guard is that big black plastic thingy that fits around the inside of the guard . If you undo the screws that hold it on ( just the ones near the antenna ) and pull it back ,you will see the antenna motor and the wires
justbad4you
IF YOR NOT A HOLDEN
MELBOURNE S/E BAYSIDE
97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
same here... i did the same on my maloo( i wish i had a switch in the cab
coasty
the voices told me to
kanwal nsw
vz equipe & vt berlina both v6
i just wired up a swith so it goes up when i want it to. just use a flat rocker switch so it looks better
