Automatic transmission is getting stuck in gear.
Discussion in 'VE Holden Commodore (2006 - 2013)' started by scouser king, Sep 11, 2016.
  1. scouser king
    scouser king Member
    Rockingham, WA
    06 VE SS
    It's been a long time since i have posted on here
    My car is now a 09 HSV Clubsport LS3.
    I have just had my car serviced: oil + filter, break flush and a transmission flush.
    Two days later i pulled out on to the freeway and the car was stuck in second gear, with engine warning and contact dealer lights. It wouldn't down shift or up shift in drive mode (D) or in semi auto mode. I still had park, neutral and reverse. I got it towed back to the the work shop that did the service and they plugged in to a computer and just turned the codes off as they couldn't find a fault.
    It drove for a day and now it's got stuck in fourth and the engine lights on. Any ideas?
  2. cruelass
    cruelass Member
    the shire
    2007 VE SS
    If it was fine before they touched it I would be back and asking them to review the work done. Maybe the filter dropped off or something. I would get someone or yourself to video the problem if you can. Try disconnecting the battery overnight may it will reset something.
  3. cewing
    cewing Member
    Castle Hill
    VE SSV SWAGON
    Probably the throttle body. Buy a bluetooth obd2 scanner for next time it plays up
